shifter adjustment - JeepForum.com
post #1 of 9 Old 01-23-2012, 10:31 PM Thread Starter
ilive4cars0122
shifter adjustment
So for the longest time now my shifter has not been adjusted properly. Not only does it not have the orange marker line up in the slot for each gear, but also after coming out of park i have to gently push it forward for reverse. Has anyone adjusted theirs before? The picture below shows the cables in front of the shifter. I tried spinning these areas with a flat blade screwdriver to adjust them to no avail.
ilive4cars0122 is offline
post #2 of 9 Old 01-24-2012, 01:27 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Pop the shifter off the lever on the trans, push the trans side lever all the way forward. Adjust the cable at the bracket til it pops back on without moving the lever.
Iirc there is a retaining clip on the cable that needs to be popped up before you can adjust it.
You can't adjust from inside the vehicle.
ratmonkey is offline
post #3 of 9 Old 01-24-2012, 02:28 AM
MarkInTombstone
These were recalled on our Jeeps. Check if you apply. If so. Freebee!
You'd be doing me a favor if you called me Mark or Tombstone, but not both.
MarkInTombstone is offline
post #4 of 9 Old 01-24-2012, 04:42 AM
KoreaZJ
1994 ZJ
Is this the recall that updates to the newer design with padding so the tranny sound doesn't transmit into the cabin?
KoreaZJ is offline
post #5 of 9 Old 01-24-2012, 04:58 AM
KoreaZJ
1994 ZJ
If it's close, I just cycle the shifter button in/out and adjust the tranny cable detent to be in the center of the shifter detent. If the shifter detent puts pressure on the cable, then it's not centered.
KoreaZJ is offline
post #6 of 9 Old 01-24-2012, 06:33 AM Thread Starter
ilive4cars0122
I could have swore it was a recall as well. The last time I entered my vin on one of the sites people post here it said there were no outstanding recalls. Above my radiator it says it was built to Canada specs though, not sure what that means in terms of u.s. recalls. Anyways thanks for the help guys.
post #7 of 9 Old 01-24-2012, 12:39 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Recall BO2 I think involved the shifter detent mechanism not going fully into park firmly. If you didn't make sure it was in park it could pop out. I found the chrysler kit Part # awhile back but dang if I can find it now. I have to bump mine alittle forward to get the key out but it hasn't annoyed me enough to fix it.
coralman is offline
post #8 of 9 Old 01-24-2012, 01:24 PM
greyhnd
I just looked at my build sheet and there is/was a recall on the Shifter Detent, the recall number is B02.
greyhnd is offline
post #9 of 9 Old 04-25-2012, 12:26 PM Thread Starter
ilive4cars0122
So unfortunately I never got around to this fix until now and it still annoys me. Anyways I took a look at it today and can someone tell me what I am missing? It will only start in park or neutral but the marker is not aligned in the spot on the shifter. Also to get my reverse lights on after I shift into “reverse” I have to push forward toward park to get the backup lights to engage. Today I took a look at the cable and when it is in “park” the shaft moves a tiny bit, but not much. I guess the part of this procedure im confused about is actually doing the adjusting. The instructions basically say to take the cable off at the mounting bracket and cable eyelet, verify it is in park then put it back on? Is the actual adjuster the clamp looking part you have to squeeze together as you pull it off the bracket? Thanks
249>242 transfer case shifter/shifter bezel questions?? kmd1776 ZJ Grand Cherokee Forum 19 03-26-2011 05:07 PM
backup light/shifter adjustment CJ7ZJman1 ZJ Grand Cherokee Forum 3 01-04-2011 08:03 PM
95 ZJ shifter adjustment freakinheep89 ZJ Grand Cherokee Forum 39 09-21-2010 05:22 PM
VIC 242 adjustment Dillonzj ZJ Grand Cherokee Forum 2 08-06-2008 05:44 PM
Shifter adjustment? ercrmr ZJ Grand Cherokee Forum 2 08-24-2005 01:00 AM
