Shift Lever - JeepForum.com
post #1 of 7 Old 04-28-2005, 01:58 PM Thread Starter
Bad_Andy
Bad_Andy's Avatar
Shift Lever
How Do I remove my stock shift lever so I can replace it.
Thanks
Andy
Bad_Andy is offline
post #2 of 7 Old 04-28-2005, 06:36 PM
jeepholic
jeepholic's Avatar
It unscrews from the floor only, they said I could remove just the handle part but I almost lost a tooth trying, they made a chrome one i saw on ebay once and the pic showed the entire unit with a plate at the bottom.
I know that's not much help, but try to put it in neutral and taking(pulling?) it off, I wasn't successful.
PS What do you own?
Good Andy
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #3 of 7 Old 04-28-2005, 07:20 PM Thread Starter
Bad_Andy
Bad_Andy's Avatar
I tried Pulling it off and that doesn't work. Thanks Anyway
I own a '98 Grand Cherokee V8 5.2 Liter AWD
Later
Andy
Bad_Andy is offline
post #4 of 7 Old 04-28-2005, 07:34 PM
Derek33
Derek33's Avatar
do you have a link to aftermarket shift nobs?
Derek33 is offline
post #5 of 7 Old 04-28-2005, 10:58 PM
scubatch2
Later
Andy
trust me, they just pull off.Not the easyest job,you may need to wear a helmit
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
scubatch2 is offline
post #6 of 7 Old 04-30-2005, 02:14 PM Thread Starter
Bad_Andy
Bad_Andy's Avatar
Ok I got it off. but now I don't know what the little black things are that have different sized holes in them. I got the new one working but it doesn't work right going in and outta park
Bad_Andy is offline
post #7 of 7 Old 04-30-2005, 02:20 PM
Derek33
Derek33's Avatar
what lever did you buy, and where did you buy it?
Derek33 is offline
Shift lever lights not working? Please help... NickFeola ZJ Grand Cherokee Forum 27 08-10-2013 07:11 PM
WJ Shift Lever flyboy14295 ZJ Grand Cherokee Forum 15 10-30-2008 08:41 AM
Shift lever removal? jason0682 ZJ Grand Cherokee Forum 5 08-03-2008 08:37 PM
Trans Shift Lever Light shashank ZJ Grand Cherokee Forum 4 03-20-2008 01:55 PM
NP 242 shift lever leak limitedman ZJ Grand Cherokee Forum 3 12-30-2007 05:05 AM
