Shift on the fly?? - JeepForum.com
post #1 of 3 Old 10-30-2009, 10:37 AM Thread Starter
Thelt
2005 KJ Liberty
Shift on the fly??
I can only put my jeep in 4wd if I first put it in Park or Neutral. Is this the way it is supposed to be? If I am in drive it will shift and the dash will say it is in but it is not in.
Thelt is offline
post #2 of 3 Old 10-30-2009, 11:00 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
I am assuming you have a 242 (selec-trac) transfer case? It shouldn't need it, but sometimes you do have to let the tension off of the driveshafts before the transfer case will shift. I have that problem between 4 fulltime and 2wd, but never the other way around. Hows the fluid looking in the tc? Might try draining it and putting in fresh.
~James
ezflip is offline
post #3 of 3 Old 10-30-2009, 12:35 PM Thread Starter
Thelt
2005 KJ Liberty
The fluid is new. I just had a shop put new seals in the transfer case.
Thelt is offline
242 Won't Shift into 2wd?!?! WVWalker ZJ Grand Cherokee Forum 8 10-23-2009 11:03 AM
ZJ will not shift into OD jersummers1 ZJ Grand Cherokee Forum 27 07-04-2009 06:59 AM
242 doesn't shift into 4WD Zoso ZJ Grand Cherokee Forum 9 04-03-2006 07:05 PM
WJ 242 shift on the fly? 01grander ZJ Grand Cherokee Forum 8 02-13-2005 10:52 PM
won't shift from 2 to 3 tommy54 ZJ Grand Cherokee Forum 4 04-19-2004 10:41 AM
