Shave a control armbushing - JeepForum.com
post #1 of 12 Old 11-20-2012, 06:59 AM Thread Starter
sevenscrew
My upper control arms are so tight in the body mount that they squeak very loud every bump or dip. Can I shave the bushing?
1997 Limited 5.2L Nelly - SOLD
1997 Limited 5.2L - new project
sevenscrew is offline
post #2 of 12 Old 11-20-2012, 07:04 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
lubricant.......
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 12 Old 11-20-2012, 07:08 AM Thread Starter
sevenscrew
Oh durr thanks. Gonna get silli spray today
post #4 of 12 Old 11-21-2012, 06:23 AM Thread Starter
sevenscrew
They still squeak alittle
post #5 of 12 Old 11-21-2012, 06:34 AM
Scopez
1994 ZJ
Moarrrrr lubricate. I would say unbolted them and then lubricate. Then you know the lub will be everywhere.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #6 of 12 Old 11-21-2012, 06:43 AM Thread Starter
sevenscrew
I'm going to rotate the body end of the passenger side 180 degrees because right now the fat end of the bushing is facing the motor. So that's half the problem. I'm also gonna put silicone paste in there
post #7 of 12 Old 11-21-2012, 11:41 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
poly bushings?
ratmonkey is offline
post #8 of 12 Old 11-21-2012, 12:49 PM Thread Starter
sevenscrew
Yes.
post #9 of 12 Old 11-21-2012, 01:16 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by sevenscrew View Post
Yes.
they'll make noise no matter what.
post #10 of 12 Old 11-21-2012, 02:05 PM Thread Starter
sevenscrew
Okay so there's not much I can do then. Thank you
post #11 of 12 Old 11-21-2012, 06:27 PM
PolkaPower
Maybe try powdered graphite lube.
PolkaPower is offline
post #12 of 12 Old 11-21-2012, 07:52 PM
KoreaZJ
1994 ZJ
My sway bar bushings are poly, the frame mount brackets have grease fittings. When greased frequently using the thickest grease I can find, they are quiet. Ignore them too long, then the "hee-haw" donkey squeaks come back, more so when temps are below 50F.
KoreaZJ is offline
