Shaking when accelerating from stop / Won't pull when in Drive - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Shaking when accelerating from stop / Won't pull when in Drive
Save 17.76% for the 4th of july with ruffstuff specialtiesIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!
Unread 03-18-2013, 09:29 PM   #1
polar8
I'm having two problems with my 96 ZJ 4.0 automatic that are definitely related. The first is that when accelerating from a stop at more than 25% throttle, the bottom of the car shakes violently. I can avoid the problem by accelerating very slowly, and once it's past 20mph I can floor it without a problem.
The second problem is that after 30 min of driving, the jeep will BARELY pull forward on its own when in Drive. You know how when you put an auto car in drive and release the brake, it pulls forward even though you're not pressing on the gas pedal? Well, my jeep barely creeps forward and if I try to give it gas it does the same violent shaking.
Any ideas?
polar8 is offline   Reply With Quote Quick reply to this message
Unread 03-19-2013, 05:39 AM   #2
ratmonkey
R.I.P.
ratmonkey's Avatar
Bad torque converter or burnt clutches in the transmission.
ratmonkey is offline   Reply With Quote Quick reply to this message
