shaking between 50-60 mph then gone - JeepForum.com
post #1 of 2 Old 06-07-2004, 06:32 AM Thread Starter
thunderchooch
thunderchooch's Avatar
I get some shaking between 50 and 60 mph then it is gone. I have a new Tom Woods front driveshaft because of my lift. So I have new U-Joints on the front of the TC. Someone told me it might be the rear shaft U-Joints? Also could it be the pinion angle? Any help on this would be appreciated!
Brian
97 Limited ZJ, 7" RE short arm
Kevinz Radiator support and shackles, Tom Woods driveshafts, OME SD-40 steering stabilizer, Cobra CB and PA, Bilstein Shocks, 35" BFG MUD TA KM2's, FM50, Surco Roof Rack, IRO Heavy Duty Steering and more to come soon!!
thunderchooch is offline
post #2 of 2 Old 06-07-2004, 08:17 PM
turk
Does it feel like the shaking is in the front or back? If in front does the steering wheel shake at all? It can very well be a result of the rear pinion angle being off. The two fixes that come to mind if it is the driveshaft are: 1) change the rear pinion angle by adjusting your rear upper control arms out. (if you have adjustable control arm, some people don't). Or 2) buy a Slip yoke eliminator.
I decided to just adjust my control arms and now... No vibration!
Turk
It doesn't matter what you drive as long as it is a JEEP.
98 JGC Laredo 4.0, 3" lift, Rustys adjustable UCA's & LCA's, Custom K&N intake, high flow exhaust, Jet chip Stage 2 and 32x11.5 BFG TA's
turk is offline
Rumbling and Shaking staggwj ZJ Grand Cherokee Forum 1 10-11-2007 06:34 PM
Shaking problem t_guenther ZJ Grand Cherokee Forum 5 10-08-2007 09:08 AM
Tremors and shaking. Airborne Lee ZJ Grand Cherokee Forum 5 08-22-2007 10:08 AM
shaking while turning TravisL1213 ZJ Grand Cherokee Forum 5 01-31-2007 08:45 AM
GC Shaking After 50? xinnocuous ZJ Grand Cherokee Forum 8 12-07-2004 10:42 PM
