Severe vibration at 70+MPH - JeepForum.com
post #1 of 10 Old 10-26-2005, 04:41 PM Thread Starter
Reswob
OK, so my Grand has started shaking a lot at speeds above 70mph. It seems to be coming from the front. Any ideas??
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #2 of 10 Old 10-26-2005, 04:46 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Rotate your tires and see if it follows a tire.
If it continues in the front it could be Death Wobble. Search the forum for that and get back to us
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 10 Old 10-26-2005, 04:51 PM Thread Starter
Reswob
I thought Death Wobble was associated with lifted Jeeps, mine is stock. I'll try the tires though, thanks.
'11 WK2 Limited 5.7
Reswob is offline
post #4 of 10 Old 10-26-2005, 05:20 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
There is no such thing as a Jeep that doesn't have the potential to get DW.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #5 of 10 Old 10-26-2005, 05:32 PM
ArloGuthroJeep
Mr. Hyde!
DW can happen when ever a component is worn out...generally bushings, steering stabelizer, or loose components.
post #6 of 10 Old 10-26-2005, 05:44 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
Drive 69!!!!!
Better number all around!!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #7 of 10 Old 10-26-2005, 06:02 PM
MAUSS
My money's on a bad tire... I had a belt separation a while back and you wouldn't believe the bulge in the tread.
'93 Limited (sold), '96 Laredo
MAUSS is offline
post #8 of 10 Old 10-26-2005, 06:46 PM
Jeep4x4nut
Jeep4x4nut's Avatar
with an all time 4wd transfer case...the front driveshaft ecspecially if a CV joint style will cause a vibration if it is broken or worn out. Id check that too.......maybe just a tire.
93 YJ | 2.5L | SOA |35 MT/Rs | 8.8/30 | 4.88s | Welded rear | Lockrite Front | Cage
95 ZJ for sale | 5.2L| F>R swap | 32 SSRs | 4.10s | Lockrite rear
Jeep4x4nut is offline
post #9 of 10 Old 10-26-2005, 06:50 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Wow,
did someone taunt the knowledge that a stock jeep can't have death wobble?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #10 of 10 Old 10-26-2005, 09:08 PM
95JpGC
Rotate the tires properly and balance them. Should fix the problem. If not, its probably a worn out component but balancing/rotating usually fixes it.
-'95 ZJ
-V8 5.2L
-Quadra-Trac
BB w/ 31 BFG ATs
Trimmed front bumper<Want a Radiator Support
95JpGC is offline
Intermittent Severe Vibration Jeep GC WK 5.7L mmain WK Grand Cherokee & XK Commander Forum 2 03-04-2013 12:17 PM
Out of no where severe oil leak masterb142004 ZJ Grand Cherokee Forum 15 07-22-2008 07:28 PM
vibrating: severe skin daddio ZJ Grand Cherokee Forum 7 01-20-2008 09:57 PM
Binding/Bucking severe in Lo goldjeep99 ZJ Grand Cherokee Forum 16 09-14-2007 06:08 PM
severe oil leak jeeptime2 ZJ Grand Cherokee Forum 4 09-27-2006 02:06 PM
