"Settling" sound in front when parked - JeepForum.com
post #1 of 6 Old 06-27-2016, 07:24 AM Thread Starter
BorderWalker
Hey guys,
So I ended up nearly a full hour extra early into work today, so I sat in my ZJ in the parking lot with the engine off while waiting before I got in. Cause, yanno, I'm lazy.
Anyway, while my Jeep sat, I noticed that there would be this loud sound I can only describe as a settling sound, like something that was tightened popping loose just a bit. It happened a couple times for the first 15 minutes, then nothing. My best guess is it's something where a bushing is bad and partially rotted away. But what I have to wonder is, what bushing?
The sound was 100% coming from the front. That much I can guarantee. And as said, it was the sound happening as the Jeep was settling in park. I've replaced many a bushings on this thing but I know of some which haven't been, so I'm asking which of them may be the most likely culprit.
1: Control Arm Bushings. All of my control arms have most likely never seen replacements. While I plan to replace them, I've been waiting for a time as I know the fronts will likely need me to get a new re-alignment, and I'd rather do everything that'd need a re-alignment like the Ball bearings and such. That's too be soon though, likely no more than a month from now.
2: Track Bar. This is the only other bushings I can think of which haven't done on the front end. I've never messed with the track bar. I've never had death wobble, so never felt a need to. I don't even know if this is a culprit, but I figured it's a maybe?
As said, never felt death wobble, so not sure whats up. Just looking for thoughts on what it might be.
Thanks
._________.ooooo.
/ŻŻŻ|ŻŻ|ŻŻ\ŻŻŻŻŻ\,____
L/ŻŻ\\__|__|"/ŻŻŻ\=llllll=\
_(Ż))===)).....(Ż))===))Ż
BorderWalker is online now
post #2 of 6 Old 06-27-2016, 07:31 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Check your sway bar links and see if the ball joint on those is torn apart.
D3<!L!>3D
S8NNG8 is online now
post #3 of 6 Old 06-27-2016, 07:38 AM
1996maroonzjf
I have heard the noise you are describing on a few different vehicles, and its the exhaust. The metal expands from being hot and after shutdown when it begins to contract it almost "pings". Different parts of the exhaust cool at slightly different rates and this cause the "ticking" or "pinging" that you hear.
I've also heard a sort of similar sound on forced air ducts in the winter right after the furnace shuts down and the ducts begin to contract.
-Tim
96 4.0 Laredo, 42RE, NP242, HP30 & D35c 3.55, OME 2.5" HD Coils, Bilstein 5100s, IRO Adj. LCAs
1996maroonzjf is offline
post #4 of 6 Old 06-27-2016, 07:38 AM Thread Starter
BorderWalker
I can confirm those aren't. I just replaced those recently and they're still in perfect shape or as near perfect after only a few thousand miles.
._________.ooooo.
post #5 of 6 Old 06-27-2016, 07:39 AM Thread Starter
BorderWalker
I've deffinetly heard exhaust systems cooling off, but this didn't sound like any I'm use too. Then again, my exhaust is pretty well banged up and needs to probably be replaced soon itself anyway.
._________.ooooo.
post #6 of 6 Old 06-29-2016, 02:31 AM
Candymancan
might be your brake pads sticking ? My jeep will creek when parked when i use the parking brake
Candymancan is offline
