Setting VIC clock without OEM headunit - JeepForum.com
post #1 of 10 Old 06-23-2013, 11:17 AM Thread Starter
RoldGold
I was just thinking ahead, is it possible to set the minutes on the VIC without having the Chrysler radio installed? If I replaced the headunit I'd lose that connection to the CCD bus and I'm pretty sure that's the only way to set the minutes.
I'd rather not lose the VIC, I like having it.
EDIT: I guess I could disconnect the battery and reconnect it right when the hour changes. Nevermind, figured it out myself!
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
post #2 of 10 Old 06-23-2013, 12:06 PM
Timo_90xj
Timo_90xj's Avatar
Huh? Chrysler radio and the VIC aren't talking between each other.. you set the VIC time from VIC, radio is set from head unit..
***Under construction***
Timo_90xj is offline
post #3 of 10 Old 06-23-2013, 01:00 PM
AVR2
96-98 VICs can talk to Chrysler head units over the CCD bus to set the time and date. However, if you have a non-Chrysler head unit, then you can just use the SELECT and SET buttons to set the time and date manually.
AVR2 is offline
post #4 of 10 Old 06-23-2013, 03:20 PM
Timo_90xj
Timo_90xj's Avatar
Well, not my VIC then '98 niner with VIC and Chyrsler stock head unit. Won't set time either way, have to set it up manually on both.
post #5 of 10 Old 06-23-2013, 03:36 PM
kg6mov
Hears the voices
kg6mov's Avatar
The VIC will just let you set the clock if it doesn't get the time from the radio, thats how it is in the 96. My niner vic communicates with the stock head unit.
kg6mov is offline
post #6 of 10 Old 06-23-2013, 05:27 PM
a70eliminator
On my 98 setting the time on the vic simultaniously changes the time on the radio.
Just push and hold set button for 5 secs, it will begin to flash the display, use the other button to scroll through functions and use set button to change, something like that anyhow.
Ok nevermind you updated your post as I was typing.
a70eliminator is offline
post #7 of 10 Old 06-23-2013, 09:20 PM Thread Starter
RoldGold
Right I understand everything said here, but when setting the time on the VIC (not by using the headunit), it only gives the option to adjust the hours and to set the date. It won't let me adjust the minutes. Normally what I do after unplugging my battery is set the date and hour on the VIC and then adjust the minutes on the headunit which updates the VIC simultaneously. Without a Chrysler headunit, there would be no conceivable way to adjust the minutes on the VIC, and I was curious as to whether the VIC will let you set the minutes when it doesn't detect a Chrysler headunit on the CCD bus.
Better yet, those of you who still use the OEM Chrysler headunit, how do you handle the buttons not working? I removed the headunit from the car and resoldered every single contact on that circuit board (which didn't help), and cleaned the bass, treble, mid, and speaker fader switches, which made those faders work better. But I don't understand why the rest of the buttons need to be mashed so hard to get them to work. If all the buttons worked nicely I would have no need to replace the headunit and therefore wouldn't be concerned with setting the clock on the VIC.
RoldGold is offline
post #8 of 10 Old 06-23-2013, 10:21 PM
AVR2
As has been said, it sure will. Looks like you've got a slightly weird problem with your VIC.
AVR2 is offline
post #9 of 10 Old 06-24-2013, 02:38 PM
kg6mov
Hears the voices
kg6mov's Avatar
If the head unit isn't there the Vic will let you set the time hours and minutes.
Sent from my iPad Nano using JeepForum
kg6mov is offline
post #10 of 10 Old 06-24-2013, 07:28 PM
jeeepguy
jeeepguy's Avatar
To set the VIC time, you press and hold the Set button until the hours start blinking, press the set button until you get the hour you want, then press the Select button to get to minutes. Repeat the process to get all of the settings done and the final press of the Select button will complete the process. Repeat the process if you make a mistake.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
