Service 4wd switch ? - JeepForum.com
post #1 of 11 Old 06-14-2013, 06:55 PM Thread Starter
a70eliminator
I'm getting this message on my vic so I pulled the switch out of the transfer case and checked continuity and it seems fine, how exactly are you meant to service the switch? The VIC is sounding off 3 series of 3 quick beeps with a pause between, along with 4 blinking wheels on the display, it says SERVICE 4WD SWITCH..
a70eliminator is offline
post #2 of 11 Old 06-14-2013, 06:56 PM
riot1987
Step one, punch VIC in the face.
Step two, Remove broken, worthless, annoying VIC.
Fin.
Build thread^^
riot1987 is offline
post #3 of 11 Old 06-14-2013, 07:10 PM
Cherokee95kid
I am too I just keep cleaning the switch itself and it helps a little but riot1987 is right the Vic does need to be punched in the face. Il be hard wiring my switch soon when i get time to do it which my dad thinks would work even though I keep telling him the Vic needs to get tossed as far as it can be into a junkyard and left there. The reason the msg keeps popping up is because of snotty soldering connections in the Vic I believe.
Cherokee95kid is offline
post #4 of 11 Old 06-14-2013, 08:08 PM Thread Starter
a70eliminator
Loose the VIC! why?
How would I know if left a door ajar or the hatch ajar, sometimes I leave my signal on, low on coolant it lets me know, a light bulb out it lets me know, ever leave your hood ajar? washer fluid low, It has a nice calender clock.
Sure I could get by without it plus alot of other things like, the overhead console display, the dimming mirrors, auto lights, heated seats, ect.
If I mostly wheeled it then yea all that unessasary electronics and bling would be gone, nothing but a seat.
post #5 of 11 Old 06-14-2013, 09:20 PM
vonericsen
All i had to do to stop this message was disconnect the switch at the transfer case...
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #6 of 11 Old 06-14-2013, 09:54 PM
StridAst
1994 ZJ
I just unplugged both the red and black wires behind the VIC to stop that annoying message. Red are supposed to be plugged in for 249 t cases. and the black for 242. (never both. one should always be unplugged) I swapped my 249 for a 242. plugged the black wires together and poof instant service 4wd switch message every time I switch out of 2wd. (no message at all when I had the red wires plugged in). almost made me rip the thing out and back over it a few times. The switch is just trying to tell the VIC what you are in. If you have a 249 where your options are 4wd full time, neutral, or 4 low, then there really is no point whatsoever to having the message displayed. if you cant tell the difference between those 3 settings, then the VIC isn't likely to help If you have a 242 I suppose it would be nice, but hardly needed to tell you what you selected with the t case. unplug the wires and you can be done with it.
To fix the message and make things work properly. I know of two possibilities. either unplug then remove the switch from the transfer case, (really easy) then clean it, and reinstall it and see if the problem goes away. OR, remove the VIC, and start resoldering connections inside until you fix whatever loose connection somewhere inside that stupid pos box that was causing the problem. (not so easy)
StridAst is offline
post #7 of 11 Old 06-14-2013, 11:06 PM
tucsonzj
Step two, use the f***** search button!
step three, Remove broken, worthless, annoying VIC.
Step four, realize that by using the search function, you were a good JF member and get yourself a beer and admire your new 2wd cubby, light switches or cb radio that replaced the VIC
Step five, smile, while drinking that beer, because you used the search function and other members didn't have to see this thread...again.
Fin.
fixed it for you. Hm, I had this message once, I logged onto JF, used that rectangle in the top left called search, lone and behold, it had been covered 1,000 times and I didn't have to post another thread about it.
Now you may ask, why did I even bother looking or posting if all I was going to do was rant about you posting a thread that's been covered. Well it's 1am, I can't sleep, and I've seen this exact thread posted 100 times in the past year. Plus I like to do little rants.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #8 of 11 Old 06-15-2013, 06:32 AM Thread Starter
a70eliminator
That search function is the first thing I tried.
I clicked on the "search" in the upper right and then used the terms (Service 4WD) I got no hits. it did seems strange that no results were found, so I simply started a new thread. Thank you very much for attacking me over it.
post #9 of 11 Old 06-15-2013, 07:07 AM
tucsonzj
Unless the search function was down, highly unlikely, in fact impossible you got 0 hits. Just saying.
tucsonzj is offline
post #10 of 11 Old 06-15-2013, 08:03 AM
rcMikeS1990
1994 ZJ
This is very true. Just search VIC in google, and voila, 10,000 vic threads pop up
1994 Grand Cherokee Limited 5.2L V8 318, Spectre cold air intake, Flowmaster Super44 muffler to 3.5" resonator tip, 30x9.5 BFG A/T's, Custom Tranny and TC shifter mod
My Build Thread--not sure how to make that the link-http://www.jeepforum.com/forum/f13/my-build-thread-1568707/
rcMikeS1990 is offline
post #11 of 11 Old 06-17-2013, 12:00 AM
eagsc7
1994 ZJ
That's Weird. Not that I don't believe you, but searching Just the ZJ Forums provided me with 239 results. 1 was yours, so 238 Other results to read. And this was Just using"Service 4WD" as the search terms.
Service 4WD Search results.
eagsc7 is offline
