serpentine squeal - JeepForum.com
post #1 of 8 Old 05-23-2011, 10:00 AM Thread Starter
FortCollinsZJ
serpentine squeal
Damn thing is squealing and driving me nuts. I replaced the belt, and the idler, to no avail. The bearings in the idler were shot, but still no luck.
It stops when it's warmed up too about 190, so right as the thermostat is opened.
I took the belt off, and the alternator pulley squeeks a bit when turning it by hand, although, when the belt is on and running, a bit of soap on the belt quiets it immediately. Leading me to think its the belt and not a wheel, but its a newer belt, and it has to be a wheel slowing down the blet right?
FortCollinsZJ is offline
post #2 of 8 Old 05-23-2011, 10:16 AM
Obie95Sahara
Mine was doing the same thing.. how tight do you have the belt? I tightened mine up a bit more & no more squeal.
Obie95Sahara is offline
post #3 of 8 Old 05-23-2011, 02:08 PM
tcar
Which engine??? They're different.
Can you tell where it's coming from?
For accessories, get a 2' long piece of garden hose, one end on your ear, move the other end around to A/C, idler, PS pump, etc.
One thing that can cause it can be the PS pully not being aligned with the belt...
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
post #4 of 8 Old 05-23-2011, 02:33 PM
ajmorell
ajmorell's Avatar
It's a 318. You can do the same thing with a screwdriver.
ajmorell is offline
post #5 of 8 Old 05-23-2011, 07:04 PM Thread Starter
FortCollinsZJ
318 is correct. The noise is definitely coming from the passenger side (its not the PS pump, it's only three months old BTW.)
The belt is tight, and is not adjustable, the 318 uses an auto tentioner.
I tried the hose trick the other day, listening at every wheel, and still couldn't narrow it down.
Yesterday after going through a car wash, the squeal was worse than ever, but again, quieted down after it warmed up.
post #6 of 8 Old 05-24-2011, 07:40 AM
yzjwk
2005 WK
My zj 5.2 has never liked certain types of belts and will always squeal if i put the more expensive belts on mad from the newer style compounds .The worst was a belt made by/for prestone .But As long as i stick to the old fasioned rubber/cloth type constructed belts - no squealing .
yzjwk is offline
post #7 of 8 Old 05-24-2011, 11:15 AM
tcar
If the carwash made it worse, it could be near the bottom of the engine. Crank pulley?
Screwdriver works better w/ engine noises, hose better w/ ancillaries.
Yes the 5.2 (318) is not adjustable. The plus is that it only takes about 30 seconds to change belts.
What kind of belt...? I think GY Gatorback is the best
98 5.9 Platinum
95 Limited V8
tcar is offline
post #8 of 8 Old 05-24-2011, 11:22 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I'll guess water pump if it stops when the thermostat opens.
I just replaced my entire tensioner assy with a Gates unit. Really was making a racket near the end. But not a squealing, more of a clacking. Try shooting WD-40 into the tensioner and see if you get a change.
HighLonesome is offline
WJ 4.7 belt squeal? tufmar ZJ Grand Cherokee Forum 8 07-31-2016 11:12 AM
WJ Squeal stew007 ZJ Grand Cherokee Forum 1 07-26-2009 09:45 AM
Belt Squeal 4.0 200KGrand ZJ Grand Cherokee Forum 1 10-08-2008 01:40 PM
Belt squeal on 4.7 HurriJeff WK Grand Cherokee & XK Commander Forum 3 02-17-2008 07:13 AM
Squeal with AC on mitchj01 ZJ Grand Cherokee Forum 5 08-05-2005 10:39 AM
