serpentine belt wont go on zj 5.2 v8 - JeepForum.com
post #1 of 20 Old 07-06-2013, 08:51 PM Thread Starter
webhostingdesig
I just replaced the power steering bracket and now the serpentine belt wont go on like it did easily before. Now I'm looking for things that can be adjusted because the automatic belt tensioner wont move far enough to the right let the belt on.
Is there something that can be adjusted like a pulley or the alternator or AC?
webhostingdesig is offline
post #2 of 20 Old 07-06-2013, 09:03 PM
WhiteOut
WhiteOut's Avatar
Do you have it routed right? If it is the same belt that came off and you got the right pulley, it can't not go on.
WhiteOut is offline
post #3 of 20 Old 07-06-2013, 09:13 PM Thread Starter
webhostingdesig
Does anyone know the proper length of the serpentine belt for the 5.2L V8?
post #4 of 20 Old 07-06-2013, 09:14 PM
WhiteOut
WhiteOut's Avatar
Is it the same belt that you took off? Or did you get a new one?
WhiteOut is offline
post #5 of 20 Old 07-06-2013, 09:14 PM Thread Starter
webhostingdesig
It's not the same belt, but before the power steering pump was broken so the pump was at an angle, essentially making the path less.
I will go compare the new belt to the old belt now, but do you know what the proper length is?
post #6 of 20 Old 07-06-2013, 09:22 PM Thread Starter
webhostingdesig
Same belt length as the old belt, but we couldn't get it to go on after we replaced the power steering pump mounting bracket and pulley. The pulley is the same width as the old pulley. The only thing that is different is that the power steering pump isn't at an angle anymore so its 1/2" to 1" long path of travel now.
I'll try it again later tonight or tomorrow.
I just want to make sure that there isn't anything else I can adjust because the belt went on so easy before we changed the mounting bracket. Is it possible that I put the power steering mounting bracket on upside down and therefore changed something?
post #7 of 20 Old 07-06-2013, 09:23 PM Thread Starter
webhostingdesig
I got a new one but I just checked and its the same length as the old belt. I'm kind of tired now so will revisit it a little later.
One thing I can think of is if its possible to bolt the bracket into the engine block upside down or sideways or is this pretty much impossible?
post #8 of 20 Old 07-06-2013, 09:40 PM Thread Starter
webhostingdesig
is it possible to put the power steering pump bracket on backwards or flipped over/inversed or wrong in anyway?
post #9 of 20 Old 07-06-2013, 10:02 PM
dnuccio
can you get the old belt on?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #10 of 20 Old 07-07-2013, 09:48 AM
David97
Shot in the dark, but are you moving the idler pulley over enough to get the belt on? lol
David97 is offline
post #11 of 20 Old 07-07-2013, 11:50 AM
AnotherRedZj
Your info says you have a V8 4. Something.....? Which is it? If a V8, then check to make sure the tensioner is in the correct position. I believe they have to be lined up right, iirc. And like said you can put the mounting bracket on wrong.
If a "4.something"......then, get a V8!
AnotherRedZj is offline
post #12 of 20 Old 07-07-2013, 12:49 PM
sebian
The problem I had when I did new PS pump and pulley was with the new aftermarket pulley. It would not seat all the way on the pump, causing an alignment issue. If this is your issue, you may need to find a different brand pump, or hit a junk yard for an oem pulley.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #13 of 20 Old 07-07-2013, 01:35 PM
kensnelling
Something I haven't seen mentioned yet, but did you get a new or used PS pump bracket? Were the casting numbers the same on both the new and the old? There were differences between 97/98 model bracket and earlier years. Different belts, too.
Ken
kensnelling is offline
post #14 of 20 Old 07-07-2013, 02:00 PM Thread Starter
webhostingdesig
Thanks guys. I have a V8 5.2L 4x4 Laredo. Everything is lined up perfectly, the new pulley is perfectly in alignment, mounted correctly and is the correct size.
Can someone tell me how to tell if my power steering bracket is mounted incorrectly (upside down or inversed)?
post #15 of 20 Old 07-07-2013, 02:02 PM Thread Starter
webhostingdesig
Ken
I bought this one.
http://www.ebay.com/itm/200910119023...S:3160&vxp=mtr
Old bracket was destroyed into little pieces. How can I tell without taking everything apart again?
