Serpentine belt size - JeepForum.com
post #1 of 11 Old 03-27-2008, 05:36 PM Thread Starter
94 greenmachine
I have a 1994 grand cherokee limited with the inline 6. I have now gotten 3 belts for it. None of which has fit. 2 of them for my a/c and one without. Went to advance and napa. Double checked the routing as well. Did not save the one that came off. Anyone else had this issue and what did you do.Thanks for any help. Need to get back on the road. This is about to make me crazy. Massive headache about it as we speak.
94 greenmachine is offline
post #2 of 11 Old 03-27-2008, 05:41 PM
Windowsrookie
What do you mean don't fit? Too small, too big? If you've tried more than one, it's not the belts' fault.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #3 of 11 Old 03-27-2008, 06:30 PM
Jeeples
Jeeples's Avatar
According to Goodyear, the belt for a ZJ w/o A/C is 71" long and 6 ribs wide. For those equipped with A/C it is 97" long and 6 ribs wide.
Remember, this is overall belt length, not circumferance.
http://www.partsamerica.com/ProductL...e=1063&PTSet=A
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #4 of 11 Old 03-27-2008, 11:15 PM Thread Starter
94 greenmachine
The 2 belts from both napa and advance auto were too long.So we tried one for the jeep with no a/c and that one was too short. I guess I will try going to the jeep dealer and get or order one.
post #5 of 11 Old 03-28-2008, 01:44 AM
platinum5.9
2003 WJ
you can take a long piece of string or something of the sort and wrap it around the pullies in order and then measure the length, make sure to be precise.
platinum5.9 is offline
post #6 of 11 Old 03-28-2008, 05:33 AM
Turbonut
Did you move the PS pump in/out to adjust the belt tension?
This would be a strange situation as they probably have sold millions of these belts for the 4.0.
Turbonut is offline
post #7 of 11 Old 03-28-2008, 06:26 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Length becomes circumference when you put the ends together
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #8 of 11 Old 03-28-2008, 01:28 PM
-Joe-
-Joe-'s Avatar
How much longer/shorter was it?
As stated the power steering pump will adjust to tighten the belt. No auto tensioner here..
The old one I removed was an inch or so longer then the new one i bought because i took it back to make sure it was the correct one..
Hard to believe 2 different stores gave you the wrong belt..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #9 of 11 Old 03-28-2008, 07:08 PM
Jeeples
Jeeples's Avatar
Sorry, I meant to say diameter, not circumferance
Jeeples is offline
post #10 of 11 Old 03-28-2008, 07:36 PM
driabyor
driabyor's Avatar
1994 ZJ
you can buy belts any length you want... If you think the belt is a couple of inches too long , just ask for a shorter belt...
anything could be the reason for the original belt not fitting.. A smaller pulley could be installed on one of your accessories..
Plus the belt could be in the wrong package also..
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #11 of 11 Old 04-10-2008, 05:02 PM Thread Starter
94 greenmachine
How do you move the power steering pump.Specifically what part or is it a bracket. Sorry trying to learn and no auto tensioner. Trying not to break anything.
Serpentine belt for 04 mmacnish ZJ Grand Cherokee Forum 5 06-22-2008 01:42 PM
Serpentine Belt Bricolage ZJ Grand Cherokee Forum 1 04-13-2008 04:24 PM
5.9 serpentine belt... help! aletheuontes ZJ Grand Cherokee Forum 2 12-27-2007 11:27 PM
Serpentine belt on WJ. rrubio ZJ Grand Cherokee Forum 9 01-06-2006 07:50 PM
Help with serpentine belt. ibms10 ZJ Grand Cherokee Forum 3 03-31-2002 09:15 AM
