Serpentine Belt Replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Serpentine Belt Replacement
Poison Spyder Dana 44 Bombshells Are BACK!!Poison Spyder RockBrawler II Rear Bumper with Tire CarrierPoison Spyder from CCOR!
Unread 06-20-2007, 11:22 PM   #1
alexofc69
I just installed a new alternator and forgot to draw out the routing for the belt. The original sticker was remove when i had my radiator replaced. So, im SOL. I have everything back together, but there is still about 3 inches of slack in the belt. Im not sure if its routed correctly??? Its a 1995 4.0 with A/C. I have found diagrams, but they are different. Any help her before I have to tow to the shop.
alexofc69 is offline   Reply With Quote
Unread 06-21-2007, 12:17 AM   #2
CLASH
ya man
95 zj, 4.5", 32" bfg at, locked rear.
CLASH is offline   Reply With Quote
Unread 06-21-2007, 06:13 AM   #3
ajmorell
There should be a diagram near the front of the engine compartment under the hood....unless someone removed it.
ajmorell is offline   Reply With Quote
Unread 06-21-2007, 08:30 AM   #4
WesTexZJ
If the one on the radiator support is missing, you can find a diagram in a Haynes manual. If you don't have one, you should get one.
WesTexZJ is offline   Reply With Quote
