serpentine belt deflection - JeepForum.com
post #1 of 13 Old 10-12-2013, 07:01 AM Thread Starter
97ZJ_FOORx4
I just replaced my alternator, made sure it was straight with the other pulleys and put my belt back on, now it squeaks when I start it and runs. I was wondering what the belt deflection should be on a 4.0 engine or what could be making it squeak. I also replaced both idler pulleys and still can't pinpoint the squeak.
97ZJ_FOORx4 is offline
post #2 of 13 Old 10-12-2013, 07:14 AM
V65Ozzie
Did you replace the belt? An older belt can make quite a racket. I know on my 97 I had to replace the serpentine belt about once a year, the dirt and mud would get ingrained into the surface, my 98 has just started squeeking now, I tightened it slightly and that helped.
Retreat? Hell, we just got here......
V65Ozzie is offline
post #3 of 13 Old 10-12-2013, 07:17 AM Thread Starter
97ZJ_FOORx4
I did not replace the belt because it didn't look bad, plus it's only like 3 months old.
post #4 of 13 Old 10-12-2013, 07:54 AM Thread Starter
97ZJ_FOORx4
I just took the belt off and replaced it with an old one I had that was in better condition than what I had....no more squeaks so far.
post #5 of 13 Old 10-12-2013, 08:37 AM
SDHarleydad
1994 ZJ
I put a new belt on a couple months ago as regular service. It was a $20 belt from o reillys. I too changed out my alt, waterpump, and pulleys. Two weeks ago the ZJ started squealing like a stuck pig. Turns out its the cheap belt from mexico. A real problem with Chrysler engines. An upgraded $40 NAPA belt... all smooth and quiet
Casper
1994 JGC Laredo
SDHarleydad is offline
post #6 of 13 Old 10-12-2013, 02:30 PM
cootertwo
1997 XJ Cherokee
Yup, I put a cheepee belt on my 97, and it has to be as tight as a guitar string, to stop the squeeling. Next time I'll spend some more $$$ on a good belt.
cootertwo is offline
post #7 of 13 Old 10-12-2013, 06:08 PM
Oldfrog
2007 WK
I learned the hard way about cheap belts. Now it's a Gates belt or no belt at all. Dont EVEN TRY to use a freakin' Dayco belt. They suck. I carry a brand new spare Gates in my spare tire cover now.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #8 of 13 Old 10-12-2013, 06:22 PM
stageninja
That Rigger Guy
stageninja's Avatar
I had a Quality NAPA belt that squealed & replaced it w/a Gatorback. Now that's a belt.
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #9 of 13 Old 10-12-2013, 10:12 PM
Oldfrog
2007 WK
Mine ate the gatorback up in a month for some reason. Went to Gates and havent looked back since. But others have had good luck with the Gatorback. Maybe I tighten mine too tight..who knows?
Oldfrog is offline
post #10 of 13 Old 10-12-2013, 11:53 PM
jbsj33p
You could also check the condition of your harmonic balancer if it comes back, look at the rubber ring between the two parts of the balancer and see if its cracked or missing pieces. When my balancer was going out it would chirp non stop.
Never trust a Jeep that doesn't leak oil.
jbsj33p is offline
post #11 of 13 Old 10-13-2013, 05:04 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Makes for good reading. The smart phone app for reading belts is kinda cool too, if I wasnot so old and cranky I might get one of those new fangled phones one day
http://www.gatesprograms.com/beltwear/beltwear
Originally Posted by HighLonesome
coralman is offline
post #12 of 13 Old 10-13-2013, 10:08 AM
zjosh93
I tighten the belt until I get about 1/2" deflection on the longest span or if you can twist the belt 90 degrees over the same span.
I have a Gates belt on my 4.0 with never any squeaks. If you give the belt a good scrubbing with a fine wire brush (and a pick to scrape out the grooves) and hot soapy water all over it really helps with squeaking. Also clean all the pulleys including using a pick to scrape all the grooves clean.
If you run the belt too tight you'll shorten the life of the bearings in your alternator, power steering pump, idler pulleys, water pump, etc.
zjosh93 is offline
post #13 of 13 Old 10-13-2013, 10:34 AM
SDHarleydad
1994 ZJ
The NAPA Micro-V is made by GATES
Casper
1994 JGC Laredo
