Serpentine Belt - JeepForum.com
post #1 of 2 Old 04-13-2008, 03:48 PM Thread Starter
Bricolage
2003 WJ
Serpentine Belt
Hey, I'm changing the serpentine belt on my '93 Jeep GC Laredo 4.0L and I am a bit confused about how I need to go about adjusting the tension. Right now the tension is so high I cannot slip the belt onto the various pulleys. So I need to loosen things up to do this. From what I know the alternator and most of the pulleys will not adjust--that it is the power steering that moves around for the belt.
I've loosened 2 13mm bolts behind the power steering and the adjusting bolt underneath. However, it cannot be moved. I tried tightening the bolt underneath several turns but it does not seem to change either way. I found a bolt underneath the p/s pulley and loosened that as well but there is no change. What am I missing?
Bricolage is offline
post #2 of 2 Old 04-13-2008, 04:24 PM
-Joe-
-Joe-'s Avatar
turning the bottom bolt counterclockwise loosens the belt.. Clockwise tightens it..
Theres 2 bolts to loosen on the front (top and bottom) and 2 on the rear then adjust it using the lower bolt thats off to the side a little, kinda hard to get to.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
Serpentine Belt Nofear6372 ZJ Grand Cherokee Forum 8 05-16-2008 10:41 AM
Serpentine Belt LargeFather ZJ Grand Cherokee Forum 8 09-01-2007 08:56 AM
serpentine belt chadburgwald ZJ Grand Cherokee Forum 1 08-23-2006 06:34 AM
Serpentine belt on WJ. rrubio ZJ Grand Cherokee Forum 9 01-06-2006 07:50 PM
Do i need a new serpentine belt? 98ZJBlack ZJ Grand Cherokee Forum 7 10-06-2004 11:55 AM
