Serious o2 sensor problem. Help - JeepForum.com
post #1 of 13 Old 01-15-2014, 11:48 AM Thread Starter
ConnorZJ413
My 98 Gc broke down this morning and it seems that my o2 sensor got caught on my driveshaft by the TCase and was ripped out at the pipe. My exhaust is fine but the "harness" that connects the o2 sensor has undergone some wire damage as well. I can find the harness and was wondering if a direct connection/splicing the 02 sensor wire to the harness wire bypassing the quick connect. Btw she just cranks and won't start, so if what is visible isn't te complete problem what else could it be in relation to the sensor? I hope it's only the wires that need to be repaired.
ConnorZJ413 is offline
post #2 of 13 Old 01-15-2014, 11:55 AM
copengrizz01
make sure none of the wires are touching each other or grounding themselves out on the exhaust or anything else then try to start it. also check if your check engine light comes on at all. can you hear your fuel pump turn on when u turn the key on? it could have fried your pcm. im sure someone else will have a better answer than me.
copengrizz01 is offline
post #3 of 13 Old 01-15-2014, 12:17 PM Thread Starter
ConnorZJ413
No dude it seems your on track. My fuel pump turns on and doesn't turn off just constantly buzzes. It did the same thing when I had a bad crankshaft sensor. But I will check the wires again. Would it be smart to cut off the whole damaged wire and directly connect the o2?
post #4 of 13 Old 01-15-2014, 12:21 PM Thread Starter
ConnorZJ413
When it happened I heard it pop out and the about 15 seconds later it just shut off.
post #5 of 13 Old 01-15-2014, 12:30 PM
copengrizz01
id cut off the damaged part your gonna have to fix it anyways. make sure none of the wires are touching each other or grounding themselves out or just try to reconnect the o2 sensor. also what ive read from googling it could have burnt the fuel pump relay. so try to swap the fuel pump relay with another one like the horn relay if the horn works. just make sure none of the o2 sensor wires are grounded out or touching each other.
post #6 of 13 Old 01-15-2014, 12:38 PM
copengrizz01
also swap the ASD relay with another known good one. it could have fried the asd relay as well. if the pump is turning on then the fuel pump relay would be good im guessing. so try swapping the asd relay.
post #7 of 13 Old 01-15-2014, 12:59 PM Thread Starter
ConnorZJ413
Ok so I'm going to buy an asd relay. And I'm realizing that after cbecking the wires werent grounded I'm getting power but my gauges aren't lifting wen I turn the key on. They all real 0 even gas gauge. There is a small damaged part which looks to be easy on the wires. Would asd relay knock out my gauges?
post #8 of 13 Old 01-15-2014, 01:09 PM
copengrizz01
im not sure if the asd would do that but i know a dead pcm would. id swap the asd relay with the horn relay before going and buying one.
post #9 of 13 Old 01-15-2014, 02:03 PM Thread Starter
ConnorZJ413
Yea the relay is fine but I'm thinking and the ground was wet. So maybe te wet ground shorted the PCM? Not sure but I think I need it looked at ��
post #10 of 13 Old 01-15-2014, 04:07 PM
Gearhead31
shorted out sensor connection with the vehicle running = very high chance of damage to PCM... Check all the fuses(even ones you don't think are related, because Chrysler is just that weird to mix them w/o labels). You can continue on the relay path as well. I hate to say it bud, but you might be out a computer..
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #11 of 13 Old 01-15-2014, 05:03 PM Thread Starter
ConnorZJ413
Ugh what a bummer. Thanks for all the advice, I think we're hot on the problem but without professional eyes I can't say. It's going to the shop and I will keep this thread updated with the problem. Make sure your o2 sensor is clear of the driveshaft! Is a PCM easy to change? I see it and looks easy, is there anything more to just connecting it?
post #12 of 13 Old 01-15-2014, 05:50 PM
ZeeJay1997
check all fuses under the hood. one of the mini 15 amp fuses powers the pcm. it usually goes when the harness gets damaged. if the 12v o2 heater voltage shorted to o2 sensor output wire, it could have damaged the PCM. it's luck of the draw when that happens. i've never known of a relay being damaged during one of these incidents.
ZeeJay1997 is offline
post #13 of 13 Old 01-15-2014, 06:38 PM
Gearhead31
x2 that it's probably not a relay(doesn't hurt to double check them all for peace of mind, imo though). To take the PCM off, it's two or three bolts(i think 13mm?) and a couple harness plugs, iirc. Not too involved. Main thing is making sure the battery is unhooked when messing with that stuff
