Sentry Key Immobilizer problems - JeepForum.com
post #1 of 8 Old 03-30-2008, 12:59 PM Thread Starter
PIAZ
Hi all,
I recently returned from a long posting overseas and my Grand cherokee(2001) has been sitting in my garage for over a year. I had a basic sevicing carried out(oil change,transmission fluids etc) and it turns out the fuel pump was not working. Changed it and the car startede.Drove it that evening but the next morning it started but the engine shut down after about 3 secs.
I looked in the manual and it mentioned the SKIS security system. I looked in the instrunt panel and indeed the sentry key lamp is on.It comes on on after the key is switched on and goes off briefly and then on again and stays on.It shuts the engine off after 3 secs. The car starts ok but dies down after 3 secs.
Can you please help,either with a bypass solution or anyother solution.for its been sitting there for about two weeks now.I have the grey key headed key but don't have the pin number as I bought the car at the Manheim car auction site!
Thanks.
PIAZ is offline
post #2 of 8 Old 03-30-2008, 01:04 PM
Jmila1901
Jmila1901's Avatar
Do you have a second key?? I hate to say it but your stuck... Get a tow to a Jeep, Dodge or Chrysler dealer and have them reprogram the key, some high end locksmiths perform the service too... A AAA premium membership is 90 dollars, they will tow up to 500 miles
Justin Mila
1993 Country XJ- AW4, 4.0 HO, Chy 8.25, Homebrew K&N Intake... DailyDriver
2002 Laredo WJ- Broken Bumper Mod... Weekend Toy
2007 Nike Dunks Size 12... Backup
Blue Jeep Club Member # 221
Originally Posted by KeepRockin024
You know your drunk when you have a little to much blood in your alcohol stream
Jmila1901 is offline
post #3 of 8 Old 03-31-2008, 08:17 PM
zjay
If the key has already been programmed, it will usually not reprogram, the DRB will tell the tech the key is already programmed to something and no longer programmable. A dealer will need to get into it, unfortunately, unless you have another SKIM key to try. It should not have happened but they do act up sometimes.
Any of the Chrysler dealers can get the skim code.
zjay is offline
post #4 of 8 Old 04-10-2008, 07:30 AM Thread Starter
PIAZ
Hi once again
I have still got this problem.
I failed to tell you that I am living abroad and there
are no reputable jeep dealers here.
It seems that on examining the key that the upper loop
Is broken by a keyring I had on it.There seem to be
some wires going through there which are now severed.
I have tried Jeep's customer service but they have been
unhelpful.
Is there some ways I can bypass the sentry key circuit?
There are four wires coming out of the imobilizer's module
under the steering column.
please help!
PIAZ is offline
post #5 of 8 Old 04-12-2008, 11:25 AM Thread Starter
PIAZ
Sentry key imobilizer 2
Hi,
I have still got this problem with the sentry key. My jeep just won't run for more than 2 secs.
It now seems that the encoded chip in the key is currupted.I have ran the onboard diagnostic test on the
Odometer.I get 111111/222222/333333/444444/555555/666666/777777/888888/999999.It seems that thiese are just standard normal codes and that all is well except for the imobilizer which blocks the whole
system.
I failed to tell you in my last post that that I am living abroad and there
unhelpful.
Someone in the forum suggests "removing the circuit and manually complete the circuit to the ignition,bypassing the chip"
Is there anyone out there who knows how this can be done?
under the steering column:
From left to right:Yellow/black
Blue/white
Black/Orange
Pink
The Imobilizer box under the steering column has the following markings:
IMOBILIZER 2
5WY7 005B
PO4686665AB
TKJ2890A2120
I have also seen imobilizer bypass systems on the web. Do they work?
please help!
PIAZ is offline
post #6 of 8 Old 02-18-2009, 02:14 PM
TupinMorgan
1999 FSJ Cherokee
Please let me know if you get an answer. I'm in the same boat (sort of). The shippers lost one key in transit and the mechanics lost the other one about 8 months ago for my 1999 Jeep Grand Cherokee. The "tow it to a dealership" doesn't work when I'm in Liberia and the closest dealership is in Baltimore, Maryland.
Some dude told me he could fly here with his computer if I bought him a plane ticket.... it all sounded fishy even though this whole thing is over my head.
TupinMorgan is offline
post #7 of 8 Old 10-08-2014, 08:11 PM
davidkusma
same problem here. same exact problem
davidkusma is offline
post #8 of 8 Old 10-08-2014, 08:27 PM
shaban
There's some bypass box that taps into CAN bus and sends the "unlocked" command to immobilizer.
It's called DEI 455T, costs about $50 on ebay.
As far as I know, DEI 455J is for 99+ models (WJ) and 455T is 92-99 (ZJ)
shaban is offline
2003 jeep GC dies while driving and won't restart because of sentry key immobilizer ron7000 ZJ Grand Cherokee Forum 8 06-27-2013 08:36 PM
Intermittant Sentry Immobilizer Johnny B ZJ Grand Cherokee Forum 6 10-28-2009 07:40 PM
Immobilizer/alarm problem Yankloverby4 ZJ Grand Cherokee Forum 4 08-27-2009 12:44 PM
Problems with Sentry Key System in 99 WJ jennzjeep ZJ Grand Cherokee Forum 4 07-31-2009 04:50 PM
Immobilizer/Sentry key problems PIAZ ZJ Grand Cherokee Forum 4 04-19-2008 04:01 PM
