selectable hubs.. - JeepForum.com
post #1 of 7 Old 08-02-2009, 03:05 PM Thread Starter
petey156
selectable hubs..
I know i am not the only one who wants some info on converting the zj to selectable hubs/
I have been searching for a few days and I cant find any info out there.. Is there any info for swaping in selectable hubs? what about a kit from warn?
petey156 is offline
post #2 of 7 Old 08-02-2009, 03:15 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
It can be done, but requires more $$ and work than it's worth.
There is no single kit made for this conversion AFAIK.
Axle shafts need to be changed. Hubs need to be changed (so you would loose the ABS sensors, thus loose ABS). Stock wheels center holes are not large enough, so they need to be changed too.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 7 Old 08-02-2009, 03:20 PM Thread Starter
petey156
what about a XJ or tj axle swap?
petey156 is offline
post #4 of 7 Old 08-02-2009, 03:30 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
The ZJ does not have the vacuum setup (harnesses or tcase vac actuator) to operate the vac d/c those use.
That would require a different tcase (with the vac switch, for which there is no spot on ZJ tcases), and a LOT of vac lines routed around.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 7 Old 08-02-2009, 05:29 PM
highlyuncntered
The tjs and later xjs never used a vacuum setup on the front axle. If you really want selectable hubs you are gonna have to swap to a non-jeep dana 44 or bigger from, say, an older chevy truck or a scout. Selectable hubs would be nice, but let's face it, it's not feasible on a jeep. it's the one thing jeep did to not make us have to get out and lock it to leave the road.
"Si Vis Pacem, Para Bellum"
'98 ZJ Limited V8 "Daisy"
highlyuncntered is offline
post #6 of 7 Old 08-02-2009, 06:38 PM
MACHJGC
Here is something you could check out...but you would still have to find shafts for it though.
http://www.reidracing.biz/DANA30.php
IRO 3" & Bilsteins
OE Skids & Recovery
255/70/16 Grabber AT2
Bumper & Roof Lights
MACHJGC is offline
post #7 of 7 Old 08-02-2009, 06:39 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
Originally Posted by highlyuncntered View Post
...Selectable hubs would be nice, but let's face it, it's not feasible on a jeep. it's the one thing jeep did to not make us have to get out and lock it to leave the road.
After you do a swap, you could always put on automatic locking hubs. I have them on my Scout, and they work great.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
4 part time/selectable locker. whats the difference? ronsaun ZJ Grand Cherokee Forum 32 12-14-2009 10:47 AM
selectable full lockers. what are some brand names? ronsaun ZJ Grand Cherokee Forum 54 12-02-2009 11:53 PM
awd to selectable 4wd Keagan27 ZJ Grand Cherokee Forum 2 04-17-2009 09:58 PM
1999 Grand Cher Limited - Convert from FT 4 Wheel to Selectable 2 or 4 Wheel? cabaynes ZJ Grand Cherokee Forum 12 12-21-2008 07:30 AM
Selectable Locker for a ZJ - OX, ARB, Ected Kcolg ZJ Grand Cherokee Forum 33 11-09-2006 04:31 PM
