Selec-Trac Problems - JeepForum.com
post #1 of 2 Old 12-26-2008, 08:28 PM Thread Starter
jstand22
Selec-Trac Problems
So the selec-trac on the '01 Laredo is acting up:
It won't fully engage unless you shift into it, shut the jeep off and let it sit for a min.
When you shift into either 4part-time or 4full-time, it seems like it doesn't engage all the way...The front pulls horribly to the left, and shakes if you go near 20 m.p.h. If you turn it off after you've put the stick into one of the 4wd positions and start it back up again the 4wd system works perfect. Same story shifting out.
Whats up?
jstand22 is offline
post #2 of 2 Old 12-26-2008, 08:58 PM
StrokedWJ
StrokedWJ's Avatar
Have you checked the fluid? How are you shifting?
If the fluid has been changed recently and the TC is full, try this trick when shifting in/out of 4wd. Let off the accelerator, shift TC into gear, slide tranny to N, blip the throttle, slide tranny back to drive, blip throttle again. I normally do this between 5 and 30 MPH and can feel the TC lever click once its completed the shift.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
Liberty Selec-Trac vs Commander Quadra-Trac II jthomaslambert WK Grand Cherokee & XK Commander Forum 13 10-30-2009 05:17 AM
quadra trac to selec trac convertion in wj JeepWJBob ZJ Grand Cherokee Forum 4 01-26-2009 10:14 PM
selec trac 4lo problems PJNovinskee27 ZJ Grand Cherokee Forum 4 04-28-2008 12:10 AM
Jeep NV242 problems (selec trac) schu98ZJ ZJ Grand Cherokee Forum 0 04-11-2007 06:51 PM
Buying Used GC: V8 + Quadra-Trac or I6 + Selec-Trac?? matt.x ZJ Grand Cherokee Forum 13 09-30-2004 11:23 PM
