selec trac 4lo problems - JeepForum.com
post #1 of 5 Old 04-27-2008, 04:55 PM Thread Starter
PJNovinskee27
i have a 01 wj. selec trac t-case. i put in 4lo today and it made this ridiculous loud bang noise. idk wat the hel it was... maybe the chain?? i hoenstly dont even know if those have the chains in it or not.
but then worst was like i couldnt go in reverse... using the pedal even it stuggled. this was when i was in 2. and it was like the torque hadnt been released. anybody have any suggestions.. help or anything
thanks so much
PJNovinskee27 is offline
post #2 of 5 Old 04-27-2008, 06:44 PM
indept
It does have a chain. Does it go forward? I wouldn't force it though, if it is the chain then it's probably jambed in the TC and forcing it could crack the TC case.
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
post #3 of 5 Old 04-27-2008, 07:07 PM Thread Starter
PJNovinskee27
ok cool thanks for the help
post #4 of 5 Old 04-27-2008, 07:59 PM
Virmagicus
Virmagicus's Avatar
Check out the linkage underneath to see if it is correctly engaged. Might be in between....
Jeff
Virmagicus is offline
post #5 of 5 Old 04-27-2008, 11:10 PM
Minivan
Mine did the same thing about a thousand miles before it completely blew up. Cracking the case into four pieces. Is it leaking at all? If so the chain streches when they get low on oil and then BAD things happen. Luckily mine broke while I was driving across country. I'm glad it didn't break in my driveway, where it would have been easy to fix.
Minivan is offline
Liberty Selec-Trac vs Commander Quadra-Trac II jthomaslambert WK Grand Cherokee & XK Commander Forum 13 10-30-2009 04:17 AM
quadra trac to selec trac convertion in wj JeepWJBob ZJ Grand Cherokee Forum 4 01-26-2009 09:14 PM
Selec-Trac Problems jstand22 ZJ Grand Cherokee Forum 1 12-26-2008 07:58 PM
Jeep NV242 problems (selec trac) schu98ZJ ZJ Grand Cherokee Forum 0 04-11-2007 05:51 PM
Buying Used GC: V8 + Quadra-Trac or I6 + Selec-Trac?? matt.x ZJ Grand Cherokee Forum 13 09-30-2004 10:23 PM
