Security system issues - JeepForum.com
post #1 of 10 Old 10-28-2005, 07:59 AM Thread Starter
LivesIn10sly
LivesIn10sly's Avatar
OK, first of all, why does my factory security system arm itself if my Jeep sits for a couple of weeks without me touching it?
2nd- since my Jeep's been sitting all summer and my battery is weak, my factory security system engages every time the battery dies...how do I just disable the thing completely? Should I just pull the fuse?
My keyless entry button hasn't worked since I got the thing, and I'm not paying what the dealership is asking for a new one. I'd just rather do away with the thing.
Thanks.
Bryan
Just got rid of the ZJ...workin' on the new CJ project..
'83 CJ-7
33x12.50 Dunlops, YJ tub, Herculiner, black diamond plate, Painless wiring, HEI
...much more to come soon...
LivesIn10sly is offline
post #2 of 10 Old 10-28-2005, 09:12 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Disconnecting the battery trips the alarm. A weak battery does the same.
Try reprogramming the remote. Follow the directions in the owner's manual to the letter. If you don't, the procedure will fail. If that doesn't work, pop it apart. Mine did this and there was a bad solder connection inside the remote. Been working for 3 years after I resoldered it.
HighLonesome is offline
post #3 of 10 Old 10-28-2005, 09:16 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
No fuse without killing lots of stuff. It's built into the ECM.
It arms when you use the power locks to lock the doors prior to closing any of the doors. In other words, to keep from arming it you need to lock the doors manually. Or you can do what I did and get an aftermarket RKE (Non IR type remote) setup that will lock and unlock my doors. The way to bypass the security system is to not lock the doors with my remote until after all the doors are closed. It's weird but it works.
It's supposed to go off after the battery is disconnected so that a thief wouldn't just unplug the battery to get past the alarm.
Yeah the IR keyless remotes (93-95) are worthless. I got a radio type (RKE) with brain, and two remotes for about $25 or so. It works great and I can use it more than 30 feet away. The IR's only work when you are standing beside the door.
Bad design, but at least they had keyless, not many manufacturers did in 94.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #4 of 10 Old 10-29-2005, 09:13 AM Thread Starter
LivesIn10sly
Do you remember where you got it? How much of a PITA was it to install?
Bryan
'83 CJ-7
post #5 of 10 Old 10-29-2005, 09:17 AM
Woody
Woody's Avatar
1985
I got it on Ebay, and I had to splice 4 wires in the drivers kick panel. Very easy.
Woody
Woody is offline
post #6 of 10 Old 10-30-2005, 09:24 AM
randyszj94
randyszj94's Avatar
1994 ZJ
woody you got the anwser for everything.. you tha mann
randyszj94 is offline
post #7 of 10 Old 10-30-2005, 09:46 AM
Woody
Woody's Avatar
1985
I try. You have to remember that I am a professional mechanic, just on airplanes which make cars look simple.
Woody
Woody is offline
post #8 of 10 Old 10-30-2005, 11:06 AM
randyszj94
randyszj94's Avatar
1994 ZJ
wish i could be as cool as you...im a welder/ stiffer fitter/ don't screw up no more/ dang that boy works a lot of overtime professional kinda guy.....
post #9 of 10 Old 11-03-2005, 08:52 PM Thread Starter
LivesIn10sly
just as a follow up...talked to Jeep, they said if I just put my key in the door, the SS will shut off (didn't know that). Also that a new remote will only cost $35 and programming will be $10.
That's better than the $95 that someone else told me it would cost.
Bryan
'83 CJ-7
post #10 of 10 Old 11-03-2005, 08:54 PM
Woody
Woody's Avatar
1985
You've got a nice dealer. However the IR remote will still barely work when standing beside your Jeep.
Woody
Woody is offline
Security system issues Samson007 ZJ Grand Cherokee Forum 6 12-03-2009 04:17 PM
Security System unclerojelio ZJ Grand Cherokee Forum 5 04-12-2008 01:00 PM
Security system?? HELP!!!! Booger32907 ZJ Grand Cherokee Forum 11 04-10-2007 01:58 PM
security system brandonsxj ZJ Grand Cherokee Forum 0 02-11-2007 12:19 PM
Security System msafrit ZJ Grand Cherokee Forum 5 05-30-2003 03:14 PM
