Security light?! Jeep wont start! - JeepForum.com
post #1 of 8 Old 04-08-2009, 10:59 AM Thread Starter
HighCrawler
Im trying to start my friends 95 jeep grand cherokee, after her battery died I installed a new one and nothing. The security light keeps flashing and it wont let me start it. Ive probed around looking for loose wires but no luck. Is there anyway to disable this VATS? Please help can some one guide me she needs it for school, Thanks in advanced
2002 Dark Blue TJ Sport, Auto, Hard-Top, 3in BDS Suspension Lift, Rubicon Wheels & Maxxis Mudders.
Christian Jeep Member#45 You can do anything in CHRIST whom strengthens you! -Philippians 4:13-
HighCrawler is offline
post #2 of 8 Old 04-08-2009, 12:04 PM
Tiggerrrrr
You need to lock and then unlock the drivers door with the key to disarm the system. If it still doesn't work theres a purple and yellow wire that needs to be cut and grounded out. There are plenty of threads with pics on the subject.
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #3 of 8 Old 04-08-2009, 04:45 PM Thread Starter
HighCrawler
Sorry I didnt mention that it does start but it turns off right away, where is this purple and yellow wire located?
post #4 of 8 Old 04-08-2009, 06:47 PM
reddevils
the key in the door lock will work
if at first you don't succeed RELOAD.i carry a .45 because they don't make a .46
reddevils is offline
post #5 of 8 Old 04-08-2009, 06:50 PM
Mickey_D
Procedure for turning off an activated alarm :
Open driver's door. Lock doors with power locks. Close door. Unlock driver's door with key. Alarm is now turned off.
Put key in ignition, start Jeep.
It really is that simple.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #6 of 8 Old 02-12-2015, 06:18 PM
stfrasure1
i have a 2002 Jeep Grand Cherokee and i have had it for 3 years and has never failed to start so i go out this morning and it turns over but will not start...IT CRANKS GREAT BUT WILL NOT HIT AT ALL, IT ACTS LIKE ITS OUT OF GAS BUT IT HAS A FULL TANK BUT THERE IS A DASH LIGHT ON FOR THE 1ST TIME THAT SHOWS A KEY WITH A CIRCLE AROUND IT WITH A SLASH MARK THROUGH IT.... Ill turn the key on and ill not hear the fuel pump kick on and the gas gauge and battery gauge dont work but the rest of gauges work so im thinking its something to do with the key dash light being on and cutting the fuel pump off but id like to know how or what i could do to fix the problem .....ALL FUEL PUMP FUSES ARE GOOD BUT ID LIKE TO HAVE ADVICE ON MAYBE RESETTING THE SECURITY SYSTEM OR MAYBE SOMETHING TO DO WITH THE KEYS..IM HOPING FOR A QUICK FIX TO ELIMINATE THAT DASH LIGHT AND GET THE FUEL PUMP WORKING AGAIN...The batery is junk now because oof trying to start it so many times which the battery wasslowly going bad in this cold whether because it like 6 yrs old...I WONDER IF A BAD BATTERY WOULD HAVE STARTED THIS PROBLEM SO IF ANYONE COULD HELP I WOULD APPRECIATE IT...THKS
stfrasure1 is offline
post #7 of 8 Old 02-12-2015, 06:27 PM
kg6mov
Hears the voices
kg6mov's Avatar
Hey there, you're on your way to getting help except for a few little things.
This (6 years dead) thread and forum section are about the 1993-1998 Grand Cherokee ZJ, your 2002 is a WJ. They have very different alarm systems.
You will get better help by creating a new thread in the WJ section here: http://www.jeepforum.com/forum/f310/
You will also get better help is you use all the buttons on your keyboard, particularly the return key. You can leave the capslock key alone though.
kg6mov is online now
post #8 of 8 Old 09-11-2016, 06:45 PM
dcjemm
@stfrasure1, I have a 97 JGC with the identical problem. Did you find a fix?
dcjemm is offline
Jeep wont start!!! -cAcHe- ZJ Grand Cherokee Forum 83 02-10-2010 05:12 PM
93 Grand Cherokee Limited 4.0 wont start... Electrical? Security? 93volsd ZJ Grand Cherokee Forum 13 02-22-2009 08:17 PM
Jeep Wont Start...Help Please raygoodson2006 ZJ Grand Cherokee Forum 4 01-02-2009 05:13 PM
Jeep wont start savethehumans ZJ Grand Cherokee Forum 7 01-07-2008 11:17 PM
HELP! Can't start my Jeep - Security Raben ZJ Grand Cherokee Forum 1 04-05-2005 10:31 PM
