security arms itself. bypass? - JeepForum.com
post #1 of 3 Old 07-05-2006, 06:56 PM Thread Starter
garoflex
greetings. have a 93 wagoneer that the security keeps arming itself all the sudden after 1 1/2 yrs ownership. last mechanic got it running, ran for couple weeks now doing it again, start & runs for 2 seconds and dies. last thing the mechanic said was he hoped it wouldnt arm itself again. i thought he bypassed it but i guess not. someone else said take the fuse out. anyone know which one?any suggestions? the thing runs great(when its running!)interior is great. i cant believe that i may have to junk-it over somthing like this! HELP! thanx
garoflex is offline
post #2 of 3 Old 07-05-2006, 07:35 PM
wmchurch
I don't know if the wiring is all the same, but I would assume it would be close. For me, I grounded out the Violet wire with the Yellow Stripe that exits the drivers door under the dash. This is the key disarm wire. That seemed to disarm the alarm forever, even if I intentionally arm it.
Do you know how it was disabled?
There is no fuse that you can pull, the alarm communicates with the PCM, the PCM needs to hear from the alarm for systems that are sold with it. I'm sure there is a way to disable this with a factory scan tool, but I don't know how.
The other thing you can try is to remove the Pink / Orange wire that connects to the alarm module. This should be the ARM signal wire that goes to the remote keyless entry module. In the 94 ZJ this is behind the glove box, but you pretty much have to remove most of the dash to get to it (if I remember correctly).
1994 Jeep Grand Cherokee Limited
122kmi
5.2L all stock baby...
wmchurch is offline
post #3 of 3 Old 07-05-2006, 07:42 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
I don't think it's a security related. It's not like 93 had transponder key (it exactly what it does , lets it run for 2 sec and that engine dies.) The way the stock alarm works on my 97, it wouldn't even let it crank.
I'd say start with your battery cables, see if there is any bad corrosion anywhere
Not sure about 93 but my 97 would not run with disconnected battery/cables even if you jump start it.
The other thing to look at would be your fuel pump.
zaq123 is offline
security system bypass deadcherokee ZJ Grand Cherokee Forum 5 03-02-2013 10:27 PM
power draw aftr security bypass ? lowflare ZJ Grand Cherokee Forum 2 12-21-2009 05:45 PM
adjustable control arms on 3.5" short arms (ride quality) 3xX ZJ Grand Cherokee Forum 7 11-29-2009 01:16 PM
Long arms or longer short arms??? OFFRDWJ ZJ Grand Cherokee Forum 65 03-29-2009 05:32 PM
long arms vs short arms. Reloader77724 ZJ Grand Cherokee Forum 5 08-11-2006 08:49 AM
