Security - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Security
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREESpartan Locker Special Forum Prices Dana 30 44 60 Ford 8.8
Unread 04-13-2014, 08:05 AM   #1
big98tnzj
Security
For those of us who are going doorless and topless, what is everybody doing to make sure that people are not getting into their jeeps and messing with or stealing things out of them like tools and stereo equipment?
Sent from my tent in the woods using JeepForum
Sent from my tent in the woods using jeep forum
big98tnzj is online now   Reply With Quote
Unread 04-13-2014, 04:06 PM   #2
Eddinger
Curious about this as well. I want to take the doors off of my 93 zj but don't know what kind of havoc will ensue. Anyone have any stories good or bad about their doorless experiences?
Eddinger is offline   Reply With Quote
Unread 04-13-2014, 10:35 PM   #3
radean84
There are alarms that have motion sensors. They usually give a warning first, then if movement keeps happening in or around the vehicle the alarm will go off. Depending where you live you probably shouldn't leave anything you're not willing to lose in a topless/doorless Jeep. In Fresno CA they break windows for cell chargers and change haha
www.ProjectZJ.com • Build Sheet and Videos
radean84 is offline   Reply With Quote
Unread 04-13-2014, 11:00 PM   #4
big98tnzj
Mine has the factory alarm but i dont have a key fob for it so i cant turn the alarm on unless my doors are on and i can lock the doors by the switch. Is there a way that i can trick the pcm to make it think the harness is plugged in and lock the doors so that the alarm will activate/deactivate?
Unread 04-14-2014, 01:33 PM   #5
Gearhead31
I don't believe our alarms are anything but switch based, with the pre 96. OBDII I know allows the option of motion sensor systems and I think it was optional on the 97+ models to have it, can anyone confirm?
If it doesn't have that, then even if you can jumper the system to thinking the doors are on, the alarm will be nearly useless unless someone tries to start the vehicle or pop the hood. The best advice I could give is don't leave anything you don't want stolen or use chain locks/padlocks/etc. And as for the radio, there are some security devices and locks you can get, combined with removing the faceplate(if you have an aftermarket) but otherwise you're pretty much stuck taking the risks.
If they are determined enough and have the time, not even an armored truck is safe from thieves. Food for thought
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
[QUOTE=JasonStebbins]We can call it the Whoosh King Catalog System. :D[/QUOTE]
Gearhead31 is offline   Reply With Quote
Unread 04-14-2014, 08:25 PM   #6
ZeeJay1997
pre 96 models security can be rendered inop by getting the vehicle running and removing the security module. this leaves the engine no run feature in the pcm permanently disarmed. alibi... i've never done this myself. i gleaned this info from this forum.
96 and up the security is inside the bcm. must reprogram to disable.
no zj has an oem security system with motion detector.
as long as the doors are off it will never arm because it thinks the doors are open.
ZeeJay1997 is offline   Reply With Quote
Unread 04-14-2014, 08:31 PM   #7
big98tnzj
I put 2 little strips of metal over my door switches to make it think the doors are closed so that my interior lights will go off but i have no way to lock it because i dont have a key fob for it
Unread 04-14-2014, 09:48 PM   #8
Gearhead31
-Ill second that, seen several threads with that, no first hand exp tho-
I was thinking that but saw something about a 97 with it.. Must've been aftermarket I guess
