Seafoam 4.0? - JeepForum.com
post #1 of 16 Old 07-11-2013, 09:33 PM Thread Starter
Dtperrell
Seafoam 4.0?
So i finally got my flowmaster 40 today and i got to thinking. While im changing the muffler i was wondering if it wasnt a bad idea to seafoam the engine. Ive had a really rough idle lately and i figured it couldnt hurt. Any opinions?
2008 JK on 35's
Dtperrell is offline
post #2 of 16 Old 07-11-2013, 09:40 PM
zjosh93
I've run seafoam through my engine a few times. Always seems to run better afterwards.
zjosh93 is offline
post #3 of 16 Old 07-11-2013, 09:44 PM
jnicewan
Its never a bad idea as long as you think it might benefit and its not going to hurt anything but a few bucks less in the wallet.
jnicewan is offline
post #4 of 16 Old 07-11-2013, 09:48 PM Thread Starter
Dtperrell
How much does a bottle cost usually?
2008 JK on 35's
post #5 of 16 Old 07-11-2013, 09:52 PM
zjosh93
about $9 around here
zjosh93 is offline
post #6 of 16 Old 07-12-2013, 06:23 AM
eagsc7
1994 ZJ
I've tried comparing prices here locally, but I think the Cheapest is $6 at Napa. Course, that's a special, and they've got a BIG sign put front advertizing it. LOL is that I've got 3 cans sitting around that are unopened. 1 can Partially used.
eagsc7 is offline
post #7 of 16 Old 07-12-2013, 07:09 AM
Kevinyj95
works good in the intake via vacuum hose. crank case is pointless. might help in the gas tank but not much. I use it in the intake whenever I clean out my TB. I run an aftermarket filter so little dust particles slip by. Cleans it out pretty good. Havent found anything better. But I use lucas fuel injector cleaner as well. Like every product its good for one thing. Its not a miracle fix all. Like they claim down at atow zone.
Kevinyj95 is offline
post #8 of 16 Old 07-12-2013, 07:50 AM
Octotat
I've used the Seafoam through the vacuum lines to clean intake on two vehichles, my 95 ZJ (145,000 miles) and on my 85 XJ (310,000 miles). The XJ could barely take off from idle it was sputtering and stalling so bad. The Seafoam was incredible in improving it. On the ZJ, there wasn't as much of an issue, but I could sense a slightly smoother acceleration.
I'm one that is usually very skeptical of snake oil, but this stuff doens't hurt and can definitely help.
Octotat is offline
post #9 of 16 Old 07-12-2013, 08:31 AM
newfieZJ
I have never used Seafoam . I just don't like the way it has to ingested by the engine . Mopar combustion chamber cleaner on the other hand I have used and love . Sprays in and cleans the throttle body while doing so . Also distributes the cleaner more evenly through out the intake .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #10 of 16 Old 07-12-2013, 09:07 AM
AaronButler
Did you change your cat when you did your muffler too? If anything, Id be more worried about the cat than the muffler. but even then, I wouldn't worry about it too much.
1996 ZJ 4.0 Laredo... you know, the one with the ripped leather seats
AaronButler is offline
post #11 of 16 Old 07-12-2013, 09:41 AM
jnicewan
They do make Sea Foam in a spray can too, among their other products. Its got a handy straw you can use that's pretty long. The straw also has an elbow piece to allow the straw to spray into the throttle body while the air intake tube is installed, this helps for some vehicles that don't run or run very good with the tube disconnected.
HERE
jnicewan is offline
post #12 of 16 Old 07-12-2013, 01:51 PM
1Aauto
Vendor
1Aauto's Avatar
I have an 89 Toro snow blower that I add 1/4 tank of sea foam to everytime I use it. It purrs like a kitten. I almost had to rebuild the carb, it surged big time until I seafoamed it. Now I use it as an additive,worked awesome.
1Aauto is offline
post #13 of 16 Old 07-12-2013, 02:00 PM
Oldfrog
2007 WK
We two stroke outboard owners wont fill a tank without it these days. Been using it for years and nothing comes close to cleaning cruddy combustion chambers or injectors and displacing water ( ethanol makes your fuel absorb 20X more water from the atmosphere). Use it in my Jeep about once a month in the tank. ( 1/2 bottle) You can tell the difference.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #14 of 16 Old 07-12-2013, 03:56 PM
chalkboard
I put 1/2 can in the gas tank and the rest down the TB recently in my 4.0. It now runs smoother and my mpg went from 14 to 15. Great stuff!!
2001 WJ 4.7/80k "Old Bones"
1997 ZJ 4.0/154k Sold
chalkboard is offline
post #15 of 16 Old 07-12-2013, 05:42 PM
booked101
I seafoam my engine just about every other month or so. Put it in the throttle body with the engine on.
good gas mileage is highly overrated.
(J)ust(E)mpty(E)very(P)ocket
booked101 is offline
