Seafoam. - JeepForum.com
post #1 of 5 Old 04-30-2011, 09:38 PM Thread Starter
shawn_in_pdx
Seafoam.
I have a 1996 Grand Cherokee, 6 cyl with 192,xxx miles on it. All in all it runs really well( finally...took care of the classic Jeep stalling issues) I'm considering running Seafoam thru my gas tank and oil. Should I? How much in each?? Is it OK to do with my mileage?? My gas mileage is bad, only mid 14's, I'm hoping to get more mileage per gallon? So....what do you think??
shawn_in_pdx is offline
post #2 of 5 Old 04-30-2011, 09:43 PM
1stblack97ZJ
http://www.jeepforum.com/forum/f13/seafoam-wow-1174246/
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #3 of 5 Old 04-30-2011, 09:52 PM
SAR-Swimmer
Good question. Seafoam has finally made it into Canada, and I've got a bottle just dying to be tried. Not sure if it's snake oil or not, but a lot of the guys on here swear by it. Where I live, if it put out half the smoke people says it does, I'd probably lose a fair bit of hair. Think I'll find a big open field, far from anyone and give it a try.
SAR-Swimmer is offline
post #4 of 5 Old 05-01-2011, 03:38 PM
freakinheep89
works great through the throttle body and through the vacuum lines, even through the gas tank. As for oil, with that many miles, it could cause more issues than it fixes. If the motor was neglected and is leaking any oil, it will make it worse. oil leaks get partially clogged by carbon build up and the seafoam eats through the build up and makes the leak worse.
If your motor isnt leaking any oil and has been well maintained, it shouldnt cause a problem. If its already leaking, it will make it worse. Otherwise, running it through the gas, vac lines, and TB is fine and works great.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #5 of 5 Old 05-01-2011, 05:28 PM
TheHalfWit
Best improvement for gas milage that I've seen is both upper and lower O2 sensors. As far as seafoam in crankcase, only if it is currently not using/losing any oil between changes, and then I'd say for 6 quarts, about 9 ounces of seafoam, call it a little more then half a bottle.
TheHalfWit is offline
mpg , seafoam
Should I Use Seafoam? ZJJay ZJ Grand Cherokee Forum 6 12-29-2009 09:02 AM
SEAFOAM....what, where, how lasvegas ZJ Grand Cherokee Forum 2 10-26-2009 11:23 PM
what is seafoam? GRDCHRKE555 ZJ Grand Cherokee Forum 8 11-11-2006 08:02 PM
Anybody ever Seafoam? Deschain ZJ Grand Cherokee Forum 6 09-22-2006 12:43 PM
seafoam randyszj94 ZJ Grand Cherokee Forum 10 08-05-2006 08:46 PM
