screws that hold the grill in? - JeepForum.com
post #1 of 16 Old 08-23-2011, 01:58 PM Thread Starter
nicklopic
Okay... so I was an idiot and when I painted my grill, I lost 3the of the screws. So today I went to the hardware store to get new ones.... but the only screw I had left fell out if ny pocket
Where can I get replacement screws or what info can I give the guy at the hardware store to get ones that would work????????
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #2 of 16 Old 08-23-2011, 02:55 PM
Jeep98_zj
Any interior body panel screw should work fine...just try it out before you leave the parking lot!!
Jeep98_zj is offline
post #3 of 16 Old 08-23-2011, 03:56 PM
Dodgeram1989
1976 FSJ Cherokee
I have a little box of replacement screws I got at O'riellys. Dorman brand. It had the screws I needed
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #4 of 16 Old 08-23-2011, 05:43 PM
Rovingbar
I replaced one of those screws this weekend. They are the same as the interior screws.
"Wherever you go have a drink"
Stock '93 Grand Cherokee ZJ - 5.2L V8 - Trans: 46RH - TC: NP249. New to me in August, 2011. Now the fun begins.
Rovingbar is offline
post #5 of 16 Old 08-23-2011, 07:22 PM
Candymancan
does it matter i lost mine tons of times, just use any old screw that fits
Candymancan is offline
post #6 of 16 Old 08-23-2011, 07:51 PM
Rovingbar
The PO replaced one of the original screws with a flathead screw. It worked just fine, but I had to grab a different screwdriver. You just need a screw with roughly the same shank size.
post #7 of 16 Old 08-23-2011, 07:51 PM
Derph
1994 ZJ
Go to a jy with a screwdriver and fill your pockets!
Derph is offline
post #8 of 16 Old 08-23-2011, 08:22 PM Thread Starter
nicklopic
I was trying to not take screws from other parts of my jeep but I guess ill just take an interior screw that fits, up to the hardware store and try to get them
98' ZJ 4.0
post #9 of 16 Old 08-23-2011, 08:26 PM
tanner1025
go to a yard and take some off any jeep
tanner1025 is offline
post #10 of 16 Old 08-24-2011, 11:26 AM Thread Starter
nicklopic
None of the interior screws seem right, the threds seem to spaced out than what I remembered and when I tryed one of the screws it messed the threds in the hole up (I think)
98' ZJ 4.0
post #11 of 16 Old 08-24-2011, 08:25 PM
Rovingbar
You know what, you're right that body screws won't work. It looks like I used a 4.8mm panhead screw. Make sure you get a set with some that are about 3/4" long. Most of the body screws seem to be 4.2mm.
post #12 of 16 Old 08-24-2011, 08:39 PM Thread Starter
nicklopic
Soooo... go to a hardware store and ask for a 4.8mm pinhead screw????
98' ZJ 4.0
post #13 of 16 Old 08-24-2011, 09:15 PM
Rovingbar
Yes, that will work. The are called panhead (not pinhead) which probably has some old meaning. They are basically rouned on the head, and flat where they come flush with the grill. Anyway, I've also discovered that I've been using the wrong screws to tighten many of my panels. DOH! Its not a big deal, but a little funny that I never noticed before.
post #14 of 16 Old 08-25-2011, 02:44 PM
tcar
Originally Posted by nicklopic View Post
pinhead screw
Funny.
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
post #15 of 16 Old 08-25-2011, 03:10 PM Thread Starter
nicklopic
Alright my bad, but I got the screws, I took one off of my friends xj and used that one to get them
98' ZJ 4.0
Bad transmission pan screws? replacement?? cata123 ZJ Grand Cherokee Forum 8 12-17-2010 11:14 AM
Good Spray Paint For Chrome Grill - Black Grill coryg23 ZJ Grand Cherokee Forum 2 06-18-2009 09:56 PM
torx screws on the PCM.... wrestlerobx ZJ Grand Cherokee Forum 8 06-12-2008 06:02 PM
IAC T25 Screws... chadburgwald ZJ Grand Cherokee Forum 7 09-12-2006 08:13 PM
screws from hell Arkansas_WJ ZJ Grand Cherokee Forum 16 12-05-2005 02:11 PM
