scored today at the wreckers - Page 2 - JeepForum.com
post #16 of 22 Old 04-13-2013, 01:52 AM Thread Starter
Treleaven
When I had my airhat on the jeep did feel more agressive but if the k&n is the same result I am going to pass as I enjoy the engine stock.
98 XJ Auto
33x12.5R15 KO2
4" w/ Fender cut n fold
Treleaven is offline
post #17 of 22 Old 04-13-2013, 10:00 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
it DOES help with off idle throttle response, more air available at the plenum will always help with that.(that's why the keg is so much better at off idle torque than the single and dual plane m1 and f1 intakes.)
ratmonkey is offline
post #18 of 22 Old 04-13-2013, 01:46 PM Thread Starter
Treleaven
Im heading back to the picknpull because im missing a couple nutz and bolts feom the intake. This orvis had a intake and exhaust on it. Im thinking ut may have a performance chip as well. Where would I look to see?
98 XJ Auto
33x12.5R15 KO2
post #19 of 22 Old 04-13-2013, 02:11 PM
MyKeyB
Makes sense.
That makes no sense. The keg is better at low rpm because of runner length and volume. It has nothing to do with anything before the throttle body. Maybe I'm misunderstanding what you are trying to say?
Should be plugged into the computer on the passenger side firewall behind the coolant reservoir.
Rust never sleeps...
MyKeyB is offline
post #20 of 22 Old 04-13-2013, 02:54 PM
PolkaPower
No performance chips are worth a damn on the ZJ unless it's a factory Mopar performance pcm.
PolkaPower is offline
post #21 of 22 Old 04-13-2013, 05:51 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by MyKeyB View Post
Makes sense.
You are. I was referring to the plenum volume difference between the keg and other intakes.
Slight increase in before throttle plate static volume does help of idle response as well, but doesn't add power, it change where the power is though.
post #22 of 22 Old 04-13-2013, 06:37 PM
MyKeyB
Ah, gotcha.
MyKeyB is offline
