scored today at the wreckers - JeepForum.com
post #1 of 22 Old 04-12-2013, 03:34 PM Thread Starter
Treleaven
Picked up a hood that replaced the one I dented up doing the durango air hat, then popped some extra rlcross bars off an orvis and got some tow hooks, with out the mounts. But when I popped the orvis hood, I found myself a nice new k&n intake. Scoooore. Debating if I am going to install it or not. Could sell it and pay for my new hoood
98 XJ Auto
33x12.5R15 KO2
4" w/ Fender cut n fold
Treleaven is offline
post #2 of 22 Old 04-12-2013, 04:35 PM
dnuccio
you shouldve taken the brackets with the hooks. the hooks are no good without the brackets
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 22 Old 04-12-2013, 04:55 PM Thread Starter
Treleaven
I want able to get the brackets yet as I had limited tools. What do you need to get the brakcets off? My zj has a bracket to hook it up to a rv so I was thinking I could attach them to that. Are they usually strong?
98 XJ Auto
33x12.5R15 KO2
post #4 of 22 Old 04-12-2013, 04:59 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
this, don't try to use them without the mounts. they're the only reason they don't rip out of the unibody.
ratmonkey is offline
post #5 of 22 Old 04-12-2013, 06:16 PM
dnuccio
all you need to get them off is a good 15mm socket, a big rachet, and some time. and a torch if theyll let you bring it in. not sure if you can use the brackets in conjunction with your rv towing brackets. if you dont tow the jeep behind an rv, just get rid of those brackets and put on the real tow hook brackets. dont try to rig up the hooks with anything else, thats just asking to get a hook thru your head, or someone elses.
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 22 Old 04-12-2013, 06:18 PM Thread Starter
Treleaven
I wont. What do I need to get the mounts off so I can go back and get those
98 XJ Auto
33x12.5R15 KO2
post #7 of 22 Old 04-12-2013, 06:19 PM
dnuccio
15mm socket, big rachet. and a torch helps if they let you use it at the wecking yard. theres 4 bolts thru the unibody, and 2 nuts with a stud plate on the lower rad support.
R.I.P. Ratmonkey
dnuccio is offline
post #8 of 22 Old 04-12-2013, 07:50 PM
zarnold
Bring some PB Blaster too.
zarnold is offline
post #9 of 22 Old 04-12-2013, 08:10 PM
AmishFury
and maybe even a bit of pipe to go over the handle of the ratchet if you need a bit of extra leverage
AmishFury is offline
post #10 of 22 Old 04-12-2013, 08:11 PM Thread Starter
Treleaven
Who has a k&n on their 5.2? Im not sure if I want to do it. I had the durango air hat and took it off because it didn't seem to run as smoothly.
98 XJ Auto
33x12.5R15 KO2
post #11 of 22 Old 04-12-2013, 08:45 PM
ThatONeJeePeR
1991 XJ Cherokee
I have a cool vue CAI that's the practically the same as the k&n. if you run it the computer will have to relearn it. I honestly got about 3 to 4 mpg increase. Not for sure the amount of hp gain but it does get up and go a bit more
Originally Posted by misterpookie View Post
*sigh* using a controller for an FPS is like trying to jump start your car with nipple clamps: simply not the right tool for the job.
ThatONeJeePeR is offline
post #12 of 22 Old 04-12-2013, 10:12 PM
StPaul59
The full K&N system on a 5.2 is awesome. I had one on my 97. Night and day difference. But I hear some people getting Amsoil filters to replace the passive K&N filter.
StPaul59 is offline
post #13 of 22 Old 04-12-2013, 10:23 PM
capcyclone
capcyclone's Avatar
^^This. If you search K&N here on the Jeep forum you'll find several threads that mention the dissatisfaction of the filter qualities.
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #14 of 22 Old 04-12-2013, 10:29 PM
StPaul59
Got one saved for future reference..
http://www.jeepforum.com/forum/f13/a...11/index2.html
StPaul59 is offline
post #15 of 22 Old 04-13-2013, 12:51 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
sorry, can't help but laugh at this.
the stock set up is able to flow as much as the motor ever needs below 4krpm.
the knn only ever adds less than 5hp at 5krpm. even the durango mod is only good for about that much(but at 15$ from most salvage yards it's a much better deal)
what was your mileage before and after? did you go from 8 with a plugged up filter to 12?
