Score. - Page 2 - JeepForum.com
post #16 of 20 Old 05-06-2013, 03:15 PM
speedbucket
Originally Posted by riot1987 View Post
hmm... maybe I should re route mine. Im gettin nervous
you should be
Originally Posted by zachjf View Post
Its only an issue if you've deleted the fuse, used too small a wire and/or are running high wattage bulbs. You'll also get a cleaner, higher amperage source of power running off the battery itself and using the relay as the switch point vs using the rocker/toggle switch.
negative, i dont care if they are direct wired with 1-00, the switch is the weak link, you can buy switches that will handle it but they aren't cheap compared to a relay. I HAVE had a switch burn up just above my right knee, it was decent sized wire, the switch burned up, grounded the hot wire on the dash/column, super heated enough to melt the insulation all the way back to battery...well guess what, it also ran through the firewall with the main harness, so it fried a bunch of those wires as well. took me an entire weekend to cut and splice wire back in. It was an 89 dakota and it never fully functioned properly again for a 2$ relay...no thanks, ill pass
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #17 of 20 Old 05-06-2013, 03:18 PM
kg6mov
Hears the voices
kg6mov's Avatar
The shorter the run of cable between the battery and the light the less voltage drop and the more light you'll get out of the lights. A relay off the battery at the light is the shortest path. Then it can be triggered by a simple switch. I run my radios the same way. They sit on a relay with high current handling and are triggered by either the auto switched outlet or a bypass switch.
Look at the write up for the kolak wiring harness for the stock lights, it's a major design flaw in these things. http://www.jeepforum.com/forum/f13/c...pgrade-660428/
kg6mov is online now
post #18 of 20 Old 05-06-2013, 03:19 PM Thread Starter
xcaliber81
I used a relay however I grounded the switch to the cig lighter ground will that be sufficient? the lights and the relay i grounded to the body grounds on the passenger fender.
xcaliber81 is online now
post #19 of 20 Old 05-06-2013, 03:21 PM
speedbucket
yes, there is next to nothing for current there, the lights are grounded right?
edit, yes you're good
post #20 of 20 Old 05-08-2013, 01:39 AM
zachjf
Originally Posted by speedbucket View Post
you should be
A 35w fog light isnt likely to burn up a switch unless its an uber cheapo china brand rocker switch which I wouldnt use even with a relay. I get what your saying and am in total agreement about using a relay but for small stuff as long as its fused lower than the amperage of the wire and switch itself there wont be a problem as the fuse will pop before the switch.
Needs parts?
PM
or
zachjf is offline
