School Me On Radiator Fan - JeepForum.com
post #1 of 7 Old 08-11-2009, 11:39 AM Thread Starter
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Before I spend $384 for a new fan I want to make sure it is bad. (dealer only item)
Heres what I have. 2004 laredo, and I believe with out the tow package as I have 355 gears. My FSM shows a 2 speed fan and I believe that is what I have. It has a low and a high speed. I have three wires going to the connector and the wire colors match what the FSM says.
By going direct to the battery, I can get the fan to run in high, but not in low.
Does anybody know for sure if the fan is suppose to run in low? I checked with NAPA and they can only get a motor or complete fan assy with only one speed (two wires going to the connector).
Any ideas or input will be appriciated.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #2 of 7 Old 08-11-2009, 01:27 PM
nashmd454
nashmd454's Avatar
I can't answer your question directly...but I would try a j yard before I ever go to the stealership.
http://www.autopartswarehouse.com/ca...g_systems.html
try here...hope this helps.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #3 of 7 Old 08-11-2009, 02:18 PM
cmonson
why do you care if the fan runs on high and low??? Just as long as it runs on high who really cares. just my $0.02.
I thought the relay controlled the high and low function of the fan. Maybe mine is different as it is a 2000.
None the less, if you had the factory tow option the electric fan isn't even there as a trans cooler is in it's place. So for a piece of mind, it really isn't required to adequately cool your jeep
cmonson is offline
post #4 of 7 Old 08-11-2009, 02:23 PM
cmonson
read through here: I guess 04 is different.
http://www.jeepforum.com/forum/f13/wj-4-0-electric-fan-high-low-speed-809932/#post7529330
One person posted here that he did not find the fan relay under the pasenger headlight on his 2004. Since I also have a 2004 I looked at mine and did not see one either. Checking further in my FSM I find there are two relays in the power distribution center - one for high and one for low speed. These relays are the last two relays in the PDC at the hinge end of the compartment. I couldn't find any mention of the TWO in the description, but in the electrical wiring section they are shown in the wiring diagram in the PDC .
cmonson is offline
post #5 of 7 Old 08-11-2009, 02:39 PM Thread Starter
michiganmaveric
Got Beer?
2011 JK Wrangler
http://www.jeepforum.com/forum/showthread.php?p=7529330
Thaks for this info. I was looking under the headlight this morning and could not see anything. I will check the PDC. Thanks again.
Lifetime member #13
post #6 of 7 Old 08-11-2009, 05:56 PM Thread Starter
michiganmaveric
Got Beer?
2011 JK Wrangler
Thats where the relays were, in the PDC. Glad I did not tear it apart or cut it all up looking for the other relay.
Took a ride into town awhile ago and the cooling seems to be better. I am begining to wonder if the wires in the connector are bad from salt corrosion. I think I will take it apart on my next days off and check the connector.
I will post up if I find this to be the case.
Lifetime member #13
post #7 of 7 Old 08-16-2009, 05:51 PM Thread Starter
michiganmaveric
Got Beer?
2011 JK Wrangler
Well I bought the fan assembly from the dealer, $407 and change. I installed it today and it works great. For quite awhile now I have been running around 210 on the temp gage.
With the new fan I am back down to the 190 range where it is suppose to be.
I took the old motor apart and it was worn out. One of the 4 brushes in the motor was not even touching the armature (sp) and the armature was worn down about a good 1/8".
The only thing I kick myself in the butt for was not having enough time to check around for the fan. After I picked up the fan at the dealer and got the part number I checked on e-bay and found one for $85 + $15 shipping. The part number for the fan is 52079528AD.
Lifetime member #13
school me about injectors austtill ZJ Grand Cherokee Forum 2 07-25-2009 10:41 AM
school me on Grands! sreno0207 ZJ Grand Cherokee Forum 21 03-14-2009 10:11 PM
School me on Overland's dz1087 ZJ Grand Cherokee Forum 6 02-11-2009 11:58 AM
School Me On Car Haulers Behind WJ CanadianZed-J ZJ Grand Cherokee Forum 5 01-09-2009 08:14 PM
radiator fan not working after replacing radiator Airborne Lee ZJ Grand Cherokee Forum 5 07-23-2006 06:53 PM
