Scary popping noises coming from front end - JeepForum.com
post #1 of 11 Old 06-22-2013, 10:41 PM Thread Starter
Xpress
This is happening when braking and turning either left or right:
http://www.youtube.com/watch?v=J7Z9u...ature=youtu.be
Not really noticeable in reverse. This axle I just put together, has some junkyard CV shafts, wondering if those might be the issue. Literally started to do it out of the blue today. Went through all of the suspension and everything is tight.
All about that unibody life.
Xpress is offline
post #2 of 11 Old 06-22-2013, 10:50 PM
jeeepguy
jeeepguy's Avatar
Sounds like bad cv joints
Rather than fix the cv joints, replace the shafts to u-joint shafts
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #3 of 11 Old 06-22-2013, 11:11 PM
papitt
Yes sound like the CV joint is bad... And it was said to just buy a rebuilt shaft. Only about 60 bucks as I remember and you get a warranty. If you tried to fix it .You'd spend 59.00 and no warranty and spend 3 days getting it going.
papitt is offline
post #4 of 11 Old 06-23-2013, 02:26 AM
Candymancan
I would just buy new shafts.. They are dirt cheap like papitt mentioned and have a lifetime warranty on them.. I replaced my 4.0's recently they had what around 140k miles on them as they were replaced about 10 years ago the originals my moms ex BF decided to slice up in a rage fit temper.. lol anway... They were like $120 total and took me about 4 hours to replace and her Jeep was rusty as heck.. but they went on fine.
Candymancan is offline
post #5 of 11 Old 06-23-2013, 08:12 AM Thread Starter
Xpress
I happen to have a set of u-joint shafts sitting around, u-joints are even good on them still. Guess I will pull these shafts out and put the good ones in then.
Xpress is offline
post #6 of 11 Old 06-23-2013, 10:33 PM Thread Starter
Xpress
Had a buddy listen from the outside of the Jeep, he seems to think it's the ring and pinion gear making all that noise. F***.
Changing to my u-joint shafts did nothing.
Xpress is offline
post #7 of 11 Old 06-23-2013, 11:55 PM
Myusername1674
For sure cv joints, my buddies jeep does this too. We're gonna replace his. Its an easy and pretty cheap fix. Just stick with cvs dont worry about u-joints.
My .02
Sent from my couch using JeepForum app
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #8 of 11 Old 06-23-2013, 11:57 PM
Myusername1674
Just saw this post. Seams unlikely that itd be ring and pinion, just from turning? That doesnt sound right. Maybe ball joins somehow? Check that as well.
(in progress)
post #9 of 11 Old 06-24-2013, 12:51 AM
Grand_ZJ
What kind of t-case do you have in the jeep?
Mine made a popping sound like that and I found out the ring and pinion was breaking (as its popping). The sound from my jeep only made the popping when I was in 4wd and driving forward but was only a pop every few feet.
Maybe its a wheel bearing.
Sent from AutoGuide.com Free App
1996 XJ Sport
Grand_ZJ is offline
post #10 of 11 Old 06-24-2013, 09:05 AM Thread Starter
Xpress
It's the awd t-case. I put this axle together from a load of parts, guess it didn't work so well. So before I break anything I'll just sell the 3 D30's I've got lying around and try to make back some $$ and pull a 3.73 D30 from the junkyard.
Xpress is offline
post #11 of 11 Old 06-25-2013, 03:23 PM
speedbucket
Spider gears
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
