Scangauge II Readings. Not Trouble Codes. - JeepForum.com
post #1 of 5 Old 07-28-2013, 01:52 PM Thread Starter
ngould1
Curious to see how these numbers compare to other ZJ's.
1996 ZJ 4.0.
All stats recorded with the Jeep 1) Engine Running. 2) Normal Operating Temperature. 3) Idle in park.
Closed loop
Idle: 740-760
MAP: 5.2-5.3
TPS: 14 (Idle). (With engine Off: 14. - With engine Off and WOT: 74 max.)
Coolant Temp: 188 degrees F
Voltage: 13.2 (+ -.1) - Engine Off Voltage: 12.4
Air Intake Temperature: 150
Ignition Timing: 16
Engine Loading: 4-6
I've found very few forums on ZJ's and Scangauge readings. Main reason I bought mine was for diagnostics.
ngould1 is offline
post #2 of 5 Old 07-28-2013, 04:02 PM
Oldfrog
2007 WK
Yeah, I'd like to know the acceptable parameters myself.... for all of the data my scanner shows.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 5 Old 07-28-2013, 06:39 PM
ZeeJay1997
here's one I took cruising down the road
IL STATUS OFF
ABSLT TPS % 23.9
ENG SPEED RPM 1970
CALC LOAD % 18.0
MAP KPA 48
COOLANT F 204
IAT F 80
IGN ADVANCE DE 37.0
ST FTRM1 % -3.4
LT FTRM1 % 0.0
VEH SPEED MPH 62
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.780
ST FTRM11 % -1.0
O2S12 V 0.660
PTO STATUS DISEN
OBD2 STAT US
ZeeJay1997 is offline
post #4 of 5 Old 07-28-2013, 06:42 PM
ZeeJay1997
and another at idle
MIL STATUS OFF
ABSLT TPS % 15.2
ENG SPEED RPM 755
CALC LOAD % 7.8
MAP KPA 53
COOLANT 123
IAT 62
IGN ADVANCE DE 17.0
ST FTRM1 % -4.9
LT FTRM1 % 0.8
VEH SPEED MPH 0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V .620
ST FTRM11 % 3.4
O2S12 V .800
PTO STATUS DISEN
OBD2 STAT US
post #5 of 5 Old 07-30-2013, 10:48 AM Thread Starter
ngould1
Old Frog, what kind of data is your scanner showing?
ngould1 is offline
diagnostic , pcm , scanner , zj
