scan tool where to plug it in? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > scan tool where to plug it in?
BLACK FRIDAY SPECIALS!! You asked, we deliver!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 04-02-2012, 07:54 PM   #1
jeepman1919
i have a 1995 jeep grand cherokee 6 cyl I was wondering if you can use a scan tool with this truck and where the plug in is located. thanks in advance
jeepman1919 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 09:13 PM   #2
mudruna
1994 ZJ
It is under the hood, passenger side, behind the battery, mine had a cap on it it's L shaped they didn't make OBDII the standard plug until 96 so you will need the correct adapter for the Chrysler OBDI plug.
94 ZJ Limited- 7" IRO premium, 4.56 gears on Elockers and Chromo's, 35" claws on beadlocks, Kevin's sliders
mudruna is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 10:34 PM   #3
ratmonkey
R.I.P.
ratmonkey's Avatar
Anything your need code wide can be had by cycling the key. Search key trick.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 04-03-2012, 12:09 AM   #4
RedRocket1994
1994 ZJ
Jeepman1919,
Does your scanner have a plug that looks like a trapezoid? If so, it will not work on your '95. That would be an OBD-II scanner for vehicles 96+ only. The scanner needed for your '95 is usually fairly expensive. All you have to do is put your key in the ignition, then (w/o actually starting the engine) go "on-off-on-off-on" within a 5-second period. Then watch your "Check Engine" light. It will flash a series of numbers, such as 1 flash, pause, 2 flashes, pause, 5 flashes, pause, 5 flashes, pause. Google the "Chrysler Key Dance" to learn more...
--Will
1994 ZJ, 5.2L/46RH, NP242 & D44HD Swap, 4" SA Lift, 31" KM2s, and all the usual... I only lifted it so I wouldn't have to drive my grandma to church anymore... ;)
Remember: Every time you call a Jeep a "car", God kills a kitten.
[COLOR="Red"]Red Jeep Club #657[/COLOR]
RedRocket1994 is offline   Reply With Quote Quick reply to this message
Unread 04-03-2012, 05:40 AM   #5
jeepman1919
thanks guys.
Unread 04-03-2012, 09:10 AM   #6
dusterdude
My 95 dakota is obdII
dusterdude is offline   Reply With Quote Quick reply to this message
Unread 11-23-2014, 12:19 PM   #7
godley
1995 XJ Cherokee
how do you scan a 95 Jeep Cherokee if you have no lights on the dash
godley is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 01:03 AM   #8
AVR2
You have to plug in a scan tool with the proper OBD1 Chrysler connector. You can buy adapters like this one to connect an OBD2 device to an OBD1 Chrysler port, but your scan tool needs to understand OBD1 protocols.
AVR2 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 01:47 AM   #9
AmishFury
generally speaking the scanners that can read obd1 also come with the connectors... prices for obd1 scanners seem to start around $150
AmishFury is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 05:07 AM   #10
AVR2
There are a *lot* of different OBD1 connectors though, so if you're buying an OBD1-capable scanner, you need to make sure that a specific Chrysler adapter is included. One probably will be, but it's not guaranteed.
Unread Yesterday, 05:27 PM   #11
godley
1995 XJ Cherokee
Thanks guys, I appreciate the info
