Save $ on rear wiper motor - Page 6 - JeepForum.com
post #76 of 93 Old 12-04-2012, 08:27 AM
bigbill888
Originally Posted by xcaliber81 View Post
Never taken it off which is why it still doesn't work duh lol, it looks easy i was just saying that my shaft looks like it will be very hard to un seize. and yes i know how to follow instructions.
The shaft has a gear on the end that is engaged with drive motor inside. It won't turn now. Take it apart, it's an easy procedure. I've done it four times on different Jeeps, always worked (100%).
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #77 of 93 Old 12-04-2012, 08:29 AM
xcaliber81
Should be easy to do, only thing im worried about is the seized shaft
xcaliber81 is offline
post #78 of 93 Old 12-04-2012, 08:50 AM
Natej_85
Im pretty sure i already stated this in another wiper motor thread with you. If it doesnt work now and you attempt the fix and it still doesnt work what are you out? Just some time and a little effort. Mine was seized for years or so i thought. Pulled it and found cracked solders easy as that. Worst case scenario is you try to fix it and still doesnt work. No biggy. Not being critical just saying give it a try.
Natej_85 is offline
post #79 of 93 Old 12-04-2012, 08:56 PM
xcaliber81
It was seized so bad that the shaft broke completely off still in the sleeve must have been that was for a VERY long time, it was actually full of rust around the yellow gear. I was told it came from down south near the salt water in or around vancouver area when I bought the jeep.
post #80 of 93 Old 12-05-2012, 06:19 PM
jonnyz123
Did this today and it works great. Thanks for an awesome write up!!
jonnyz123 is offline
post #81 of 93 Old 04-19-2013, 03:54 PM
hilroy97
Thanks OP for the post. Figured it was a shaft issue and will find out over the weekend.
Had similar problem with a 98 Nissan Pathfinder. The fix was easier as it didn't involve the circuit board removal.
Always used Nev-R-Seize on the shaft after.
Ed
hilroy97 is offline
post #82 of 93 Old 04-27-2013, 04:47 PM
JeepNicholson
My rear wiper has never worked until today. Cleaned the shaft as per the OP's instructions although I used a steel brush wheel to do it, worked like a charm! Regreased everything and put it all back together, and BAM I've got rear wiper action...Also resealed the gaskets to avoid having to do this again, even though it was actually pretty easy....
Great write up!
Now I just gotta get my wiper blade back from my ol' lady, since she talked me into letting her put it on her CR-V
JeepNicholson is offline
post #83 of 93 Old 05-05-2013, 02:21 PM
cyberbonga
Hello there, first of all, really nice write up, helped a lot of owners and saved them few $. Actually I applied the same procedure before reading this thread but had some problems which are mentioned in this thread as well, couldn't figure out how to resolve, but 2 days back, it just worked and I found the secret, thought of sharing as I read there are many who followed the procedure and ended up with single spin or not spinning at all.
It's true that it is good to "mark" the gear inside, but it is not that difficult to find the correct placing. I never marked the thing, and I faced the same problem of single spin. Finally I gave up on that and reassembled the motor and the back cover. After packing everything, when I started the jeep, i noticed it working problem free.
So the trick was that the motor would not work untill you close the trunk door, As far as the trunk is open, the sensor will stop the motor from spinning, and that was the mistake I was doing that after cleaning the whole thing, I was testing it by just connecting the wire (trunk door opened), so all you guys who have gone through this procedure and are still facing problems, remember to close the trunk before you give it a try
Hope this helps!
cyberbonga is offline
post #84 of 93 Old 07-14-2013, 03:11 PM
jeepgrandcher98
For gomes512,
Great write up! However, I missed the part about marking the wheel before taking it out of the shaft, and now I can't seem to put it in properly. Do you have a suggestion as to how I can align the wheel so it will fit properly? Thanks!
EDIT: I also have tried plugging it in while the trunk door is shut. Everything is working except the wheel will not spin in the shaft.
jeepgrandcher98 is offline
post #85 of 93 Old 07-22-2013, 09:15 AM Thread Starter
gomes512
1994 ZJ
It's been so long since I did this, you have to look at the gear face (it has the contact) and the arms on the motor body. Try different start positions by moving the gear forward or back a few notches.
gomes512 is offline
post #86 of 93 Old 10-23-2013, 06:36 PM
Gearhead31
Just marking this so I can follow it when the rain clears up. Hopefully all goes well!
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #87 of 93 Old 01-25-2014, 12:35 PM
stuartbeattie
2003 WJ
Big thanks gomes512,
BUT, my other half own a Jeep WJ Grand Cherokee and I joined here on her behalf, we're from the UK, Scotland Perth to be exact and I own another vehicle and belong to another forum and sadly i have the same issue here!
The guys in the know will stay in the know because you missed a major part of this operation.
I dont have a clue how to get in to the back panel of the tailgate and as wondrous as your post is, I still have to do some studying to get to where you got before this amazing post!
My Lady is agog to find she is stressed to worry over a lack of rear wiper as she has a lot of mileage to do and the rear wiper has been playing up!
Basically, it goes 1 wipe then stops, sometime on the other side or just one wipe then it parks up.
I do not plan on opening up the tailgate but will employ part of your great post but i am not electrically qualified or trained to do what you have done with the circuit board, but hey judging by the overwhelming gratitude displayed by fellow members, you must all be!! (No engineer jokes here! )
Thank you and I mean it, a big help would have been a link to "opening up the tailgate", but it must be difficult as there are so may different models concerned so I empathize greatly!!
So I end in saying a big thank you none the less! Surely my Girl has gone mad trying to find a cure, OR a new rear wiper as she has looked for a few hours and has been totally frustrated by the lack of info in general on the net and especially in the UK!
And to our American friends please stay as you are, great going thanks! we DO have friends, thank you !
PS and a big PS too, does anyone have the part number of the Grand Cherokee WJ 2003 2.7crd rear wiper motor? Any onfo much appreciated!! Thanks in advance, Stu
stuartbeattie is offline
post #88 of 93 Old 03-02-2014, 06:36 PM
Acc0919mc
I went to do this today, went to undo the nut for the wiper arm and snap goes the shaft. I busted that thing right off. Looks like im ordering a new one
Acc0919mc is offline
post #89 of 93 Old 03-02-2014, 06:45 PM
Compgeek789
1994 ZJ
I had to order a new motor too, cause the old one was completely seized up.
RIP 1994 ZJ 5.2
Compgeek789 is offline
post #90 of 93 Old 04-21-2016, 12:30 AM
grandcherokee19
My 1998 grand Cherokee continuously seizes rear wiper motors, what do I do? I took it to a shop and they couldn't figure it out. They replaced the motor with a brand new one , it works for 5 minutes then seizes. They tried 3 different brand new motors and same thing kept happening
grandcherokee19 is offline
Rear wiper motor, $150 michiganmaveric ZJ Grand Cherokee Forum 7 04-20-2008 01:11 PM
rear wiper motor Maciej ZJ Grand Cherokee Forum 12 02-17-2006 09:56 AM
94 GC rear wiper motor calvin12 ZJ Grand Cherokee Forum 6 03-18-2005 09:41 AM
rear wiper motor alpine ZJ Grand Cherokee Forum 3 12-17-2003 02:00 AM
Need Rear Wiper Motor evalasek ZJ Grand Cherokee Forum 3 04-04-2002 09:04 AM
