Saggy/boat feeling in my ZJ. shock/springs upgrade? - Page 2 - JeepForum.com
post #16 of 23 Old 06-10-2013, 08:18 AM
PolkaPower
I just replaced the whole arm with moogs from rock auto. The uppers are a bit different in the front since the bushing is in the axle. They don't see nearly as much stress as the lowers do though.
PolkaPower is online now
post #17 of 23 Old 07-14-2013, 12:35 AM
Mike-W
Can you away with replacing one rear arm at a time or should both be done?
Mike-W is offline
post #18 of 23 Old 07-14-2013, 09:43 AM
PolkaPower
Do them one at a time but both in the same day. No sense in having the new bushing take all the load from the sloppy old ones. You will just wear it out faster.
post #19 of 23 Old 08-31-2013, 12:12 PM
Mike-W
Ok so going to change the lower rear control arms, can I just un bolt they or do I need to support / jack anything?
Mike-W is offline
post #20 of 23 Old 09-12-2013, 01:55 AM
Mike-W
Got the old one off but can't get the bolt to align on the new one is out by a few mill, is there any tricks or suggestions any can offer?
Mike-W is offline
post #21 of 23 Old 09-12-2013, 04:14 AM
RagTagSoldier
Put I screw driver through the holes and muscle it into place
Sent from my iPhone using JeepForum so it probably looks goofy.
RagTagSoldier is offline
post #22 of 23 Old 09-12-2013, 05:57 AM
newfieZJ
Very confused as to how a control arm bushing effects height for a spring , maybe this can be better explained cause , I wanna hear it !
That don't mean they are good , I replace them all the time on any ZJ I buy . I just don't see what this has to do with height .
If you were parked on level ground doing those measurements , you have a weak sagged spring . 18" fender to hub is the stock starting point except UC which can be over 1" more , suppose to be 19" . Double check your measurement in different parking spaces
Cheap fix , toss a 1" spacer on the spring .
Best fix , replace springs with new
For a no boaty feeling replace the sway bar frame bushings minimum ever 2 years , front and rear . IMO , it's the most abused bushing on the whole jeep . If you really want it gone , buy a rear Adcco sway bar
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #23 of 23 Old 09-12-2013, 07:25 AM
JeepNicholson
You don't need to raise anything, but chock the front and rear wheels(on both sides) to keep your axle from moving on you.
JeepNicholson is offline
