is this safe? - JeepForum.com
post #1 of 11 Old 12-08-2011, 11:25 PM Thread Starter
reeds86xj
is this safe?
I'm getting 2"BB and I have 3/4"BB already, so my question is can I run both spacers at once? Like the 2" on top of the spring and the 3/4" on the bottom? So it would go axle, 3/4"spacer, spring, 2"spacer, spring isolater, then body. Will it be safe?
1996 ZJ Laredo 182,000 4.0L Auto, 3" lift(upcoutry springs and 2"BB), 31x10.50 A/T's, Dana 30/35 3:55's, Cobra 29LTD, Thrush Turbo Muffler
reeds86xj is offline
post #2 of 11 Old 12-08-2011, 11:42 PM
zander21510
I've always understood never to stack spacers...something tells me even on both sides of the spring it would be more unstable. But I could be wrong. Personally I wouldn't try it.
zander21510 is offline
post #3 of 11 Old 12-08-2011, 11:44 PM
KingtheZJ
you cant put a spacer under the coil. it needs to sit down into the coil bucket and have the retainer on it
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #4 of 11 Old 12-08-2011, 11:48 PM Thread Starter
reeds86xj
So can't use bot spacers then?
post #5 of 11 Old 12-08-2011, 11:50 PM
zander21510
No. 3/4 inch isn't worth an unstable and potentially dangerous suspension.
post #6 of 11 Old 12-08-2011, 11:50 PM
KingtheZJ
what? bottom?
no, all spacers need to be on the top. and i would not recommend stacking a .75, 2, factory isolator. too much stacking. if you dont want coils (can usually find them used cheap) then get 3" spacers. be sure to extend the spring post on the rear or when you flex i could unseat the coil on the top.
'88 XJ
post #7 of 11 Old 12-09-2011, 02:26 AM
HeavyArms
Originally Posted by KingtheZJ View Post
what? bottom?
curious as to if he could use the 3/4" pucks in place of the iso's?
Wiggle wiggle wiggle
HeavyArms is offline
post #8 of 11 Old 12-09-2011, 08:51 AM
KingtheZJ
they are both 3/4". neither has an advantage over the other
'88 XJ
post #9 of 11 Old 12-09-2011, 08:53 AM
HeavyArms
I was just thinking that perhaps his 3/4" pucks are in a bit netter shape then his iso's.
post #10 of 11 Old 12-09-2011, 08:57 AM
KingtheZJ
possibly, but the isolators have a metal canter, which makes them more rigid. after thinking about it a little more i think i'd recommend to go coil, isolator, spacer.
'88 XJ
post #11 of 11 Old 12-09-2011, 09:02 AM Thread Starter
reeds86xj
Thanks, that was gonna be my next question cause I didn't know what order they went in.
