a sad day in the life of a young jeeper - JeepForum.com
post #1 of 27 Old 03-30-2013, 05:26 PM Thread Starter
JeepDaddy1993
Well today i was driving after dropping my girlfriend off her Debit card while she was at work. My throttle stuck and i couldnt get it to slow down fast enough and slammed into a concrete barrier my frames mangled up front on the passenger side. I fear that there may be no hope for my beloved jeep but im gonna see if it can be stretched back. If not i guess its round 2 of jeep searching
JeepDaddy1993 is offline
post #2 of 27 Old 03-30-2013, 06:15 PM
dnuccio
1st off im glad youre ok, but why the hell wouldnt you just turn the key off to cut the motor?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 27 Old 03-30-2013, 07:55 PM
Treleaven
Also glad to hear your okay. Has anyone else experienced a stuck throttle in there ZJ before? I have never heard of that happening before so far.
98 XJ Auto
33x12.5R15 KO2
4" w/ Fender cut n fold
Treleaven is offline
post #4 of 27 Old 03-30-2013, 09:08 PM
93zjlimited
Glad that you're ok. Today mine stuck for a split second because its so worn out the plastic sleeve caught on something. No matter what your driving if it ever happens again, don't panic and just pop it into neutral and turn the key off. A serious injury or a life is worth more than a motor.
93zjlimited is offline
post #5 of 27 Old 03-30-2013, 10:24 PM
MyKeyB
DO NOT TURN THE KEY ALL THE WAY OFF!!! THE STEERING WHEEL WILL LOCK AND YOU OR SOMEONE ELSE WILL DIE!!!
Okay, maybe no one will die but just go back one click on the ignition switch to kill the engine. Don't forget if the engine is not running the power brakes and power steering are no longer working. You can still steer and brake but it will be tougher.
MyKeyB is offline
post #6 of 27 Old 03-30-2013, 11:59 PM
Myusername1674
Dang that really sucks man! Sorry to hear that.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #7 of 27 Old 03-31-2013, 12:49 AM
riot1987
I had my first Jeep in high school and drove it for years. The Transmission went out, I fixed it. Then the CPS went out and it sat for 6 months while I dicked with it to figure out what was wrong with it. I fixed it. Then it was running great and I dumped a bunch more money in it. Then drove it into a frozen pond and drowned it. Fixed it. Then Build bumpers for it and again, dumped a bunch more money in it. A week later I T-boned a guy in which I totaled it.
I now have a better more capable jeep. I learned A LOT from the entire thing and my current jeep is way more *****in than the old one was.
So-
At least youre safe.
And
Your next rig will most likely be more badass than this one was.
Still sucks though chief..
At least youre safe
Build thread^^
riot1987 is offline
post #8 of 27 Old 03-31-2013, 01:21 AM
1slo_camaro
Not completely true.... when you kill the key completely you will not lose power brakes completely, they run off vaccuum/psi when you kill the power you normally have one full pump of your pedal assisted before you lose air in your brake booster, but enough to stop you quickly unless you are doing 90.
to the OP glad to hear you are ok and able to come on and post about it, if you have/had any money in the jeep pull off the good stuff and find another with the insurance $$..... its not worth trying to straighten a frame out especially on a unibody like a ZJ, if it was a full framed vehicle yea go ahead and just box the section in, but i wouldnt trust it with a unibody vehicle. good luck man
1998 ZJ~~V.r 4~~4.0 with a bunch of fancy stuff that makes it look pretty sitting in the driveway.
PM me for 99+ intake manifolds for sale
$125-sandblasted and painted and shipped
1slo_camaro is offline
post #9 of 27 Old 03-31-2013, 09:08 AM
dnuccio
the key wont turn all the way back even if you tried. The trans has to be in park for it to release the key.
R.I.P. Ratmonkey
dnuccio is offline
post #10 of 27 Old 03-31-2013, 09:10 AM Thread Starter
JeepDaddy1993
Buying another this weekend same year color motor and less miles and swapping everything i want out from the old one. Its a very rough loss on my first jeep that i bought and put all of my blood sweat and tears into its like losing a family member yah know
post #11 of 27 Old 03-31-2013, 09:37 AM
riot1987
I know exactly. You will have a **** ton of extra parts though..
Build thread^^
riot1987 is offline
post #12 of 27 Old 03-31-2013, 12:41 PM
leadfootny
I had the TPS fail on my 5.9 on the highway once. Made the engine run at WOT. Made life interesting as it quickly approached 100mph. Threw it in neutral and pulled off as quick as I could. The rev limiter should protect the motor long enough to get off the road and shut it down without any damage. Glad to hear you are ok. Lesson learned and you lived to tell your tale.
96 ZJ 4.0
98 ZJ 5.9
leadfootny is offline
post #13 of 27 Old 03-31-2013, 12:48 PM
dnuccio
how would the TPS do that? it just tells the computer the throttle position. the actual throttle lever on the throttle body is controled by a cable to the pedal
R.I.P. Ratmonkey
dnuccio is offline
post #14 of 27 Old 03-31-2013, 12:50 PM
xcaliber81
i am pretty sure the key will turn to off in neutral as well.
xcaliber81 is online now
post #15 of 27 Old 03-31-2013, 01:18 PM
dnuccio
nope only in park. at least thats how mine is, just tried it. try on yours and see.
R.I.P. Ratmonkey
dnuccio is offline
