?s about lifting my GC - JeepForum.com
post #1 of 10 Old 02-15-2003, 04:03 PM Thread Starter
demtjcj
well i just posted about lifting my grand cherokee. i decided to go with RE. i have heard lots of good things about them. so i call them up and say that i have a 93 GC with the 6cyl and quadra-trac(all time 4wd). he informs me that i can only go with the 3.5" lift du to the fact that it is all time 4wd. he said i cant do a cv driveshaft/ or a cv and sye. so he said the most i could go was 3.5 due to drivline vibrations that occur. so i was wondering if i could do a 1.5"-2" tc drop to help level everything out. or does this put to much stress on other components dropping them that much. let me know what you think.
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #2 of 10 Old 02-16-2003, 09:13 PM Thread Starter
demtjcj
btt
demtjcj is offline
post #3 of 10 Old 02-17-2003, 03:33 AM
Howler
That is a typical RE respone. I'm at 4.5-5" lift and no vibes with the Quadra trac. I can list off about 20 others that have the same thing. As for the driveshaft you already have a CV driveshaft. However I think he is refering to what SWB people refer to as a CV but we call it a double Cardan which you already have as well. Whart was his reasoning behind his respons?
What size of lift are you looking at anyway?
Holwer
97ZJ 5.2L with 5" lift. 31" SuperSwampers TSL
To boldly go were no Grand has gone before.
Howler is offline
post #4 of 10 Old 02-17-2003, 09:48 AM Thread Starter
demtjcj
so basically you have have inches and do not have any vibes. do i not need to change my drivshaft since it is already a cv style. i was looking at the RE 4.5" with 1" spacers as well. clearing 32/33s. depending on what tire fits.
demtjcj is offline
post #5 of 10 Old 02-17-2003, 09:49 AM Thread Starter
demtjcj
what is swb
demtjcj is offline
post #6 of 10 Old 02-18-2003, 03:48 AM
Howler
I did a front to back swap and netted about 4.5" -5" and no I have not had any vibes. However I just want to say that every ZJ is different and vibes and death wobble can happen but it can also be fixed. Oh and SWB means Short Wheel Base like a TJ, YJ, CJ. The term LWB is a long wheel base like and XJ ZJ, WJ, KJ. Anyway to answer your question on the shaft I believe that at 5.5" of lift you will be border line on a new shaft. What happens is that if you replace you control arms with the RE kit then the shaft is not long enough to reach properly. Basically out of spec. The CV style driveshaft that you have is adjustable even though they never say it. How you adjust it is by loosening the lock nut and moving the shaft. However what you need to adjust it to I do not even have a clue. I just know that in my case with 4.5" lift and stock control arms my shaft actually has to be shortened. With the lift I have now moved my front axle closer to the Tcase. Here is a write up from a friend of mine who has the same set up as me. Maybe it can help you as well.
http://www.zjilla.com/tech_Type3.htm
Howler
Howler is offline
post #7 of 10 Old 02-18-2003, 08:08 AM
Beerman
well I'm at 5 inchs with the quadrac and no problems
93 Grandcherokee limited V8 with lockers,lift,winch and other things
Beerman is offline
post #8 of 10 Old 02-18-2003, 08:53 AM
Howler
Originally posted by Beerman
well I'm at 5 inchs with the quadrac and problems
What problems would that be? And is this the same Beerman that is a guide for GSE? If so I know why you have problems.
Howler the lonely Canuk
Howler is offline
post #9 of 10 Old 02-18-2003, 08:58 AM
Beerman
Sorry missed a word I have no problems
And yes this is the same Beerman and what do you mean you know why I would have problems?
Beerman is offline
post #10 of 10 Old 02-18-2003, 09:50 AM
Howler
I was behind you at GSE. LOL Just kidding. I don't think it was the driveshaft that was vibrating but the trailer you were towing.
Howler is offline
lifting more after a SYE JaredWJ ZJ Grand Cherokee Forum 11 11-30-2008 03:41 PM
lifting a '98 zj TheDude584 ZJ Grand Cherokee Forum 11 11-30-2006 06:56 PM
Lifting a 2WD... FullForceSound ZJ Grand Cherokee Forum 2 05-16-2006 11:22 AM
Lifting my ZJ ZJDan ZJ Grand Cherokee Forum 15 04-19-2006 09:32 AM
lifting a 94 GC? Lizard King ZJ Grand Cherokee Forum 14 12-11-2005 11:05 AM
