Rusty's tow hook kit - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rusty's tow hook kit
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiFree shipping on slip yoke eliminator kits New lower PriceNew! JK/U skid plate system.
Unread Yesterday, 06:24 PM   #1
zjmaster
Hi all, this is my first post here. Has anyone installed the tow hook kit from Rustys offroad on their zj? I have a 95 and the front bumper is part of the uniframe. In their instructions they say the bumper bolts on, so their kit will not mount on my zj as they say. I was hoping to get these installed this weekend with a long list of other mods . In two weeks we are off to play in Moab in the GSW group. Thanks
zjmaster is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:07 PM   #2
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I installed a set many years ago. No problems on a 94.
Some of the supplied bolts were a bit long is all I remember.
HighLonesome is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:46 PM   #3
JaimeZX
Why not hit the junkyard and pull a set of factory tow hooks? That's what I did. Cost me $12, plus some elbow grease and a little time. The Rusty's hooks appear to be about identical and clearly bolt up to the same holes in the frame.
Set your radio clock!! http://www.jeepforum.com/forum/f13/1993-zj-radio-cassette-clock-623659/
JaimeZX is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:37 PM   #4
kg6mov
Hears the voices
kg6mov's Avatar
If you got the right ones they are the same design as the stock ones. Should be pretty easy. You need to remove the bumper cladding which is what they mean in the instructions when they say remove bumper but retain bolts.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 11:37 PM   #5
tjcustomranger
Does anyone know what the factory bolt sizes would be? Just in case i see some when im in the JY
tjcustomranger is offline   Reply With Quote Quick reply to this message
Unread Today, 05:01 AM   #6
zjmaster
Thanks for the responses, with the cladding removed I see no holes to bolt them to. maybe I'm not seeing it right.
Unread Today, 07:06 AM   #7
Scopez
1994 ZJ
Look in the 2 frame rails
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline   Reply With Quote Quick reply to this message
Unread Today, 07:59 AM   #8
JaimeZX
IIRC the bolt heads were 3/4" but they could have been 15-18mm. Bring a bunch of stuff in that size range. And penetrating oil. I twisted the heads off four of 10 bolts when I was pulling mine.
Unread Today, 08:31 AM   #9
tjcustomranger
Thanks
