Rusty's Long arm Kit - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rusty's Long arm Kit
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 02-05-2008, 10:51 AM   #1
Scottso699
2006 WK
I was just wondering overall what everyone thought about Rusty's Long arm kit - specifically I am looking to get some input from people currently running it - I ordered one yesterday and would like to know some thoughts on the matter. As a background on the subject my upper rear control arm bushings ripped off the frame (again). SO.... I decided on long arm kit that can be put on by garage mechanics and is somewhat affordable. I have no experiance welding and the brackets were welded back on last time by a little mexican guy (great welder by the way...) that only knew where to weld if I pointed to it. (Didn't speak a spit of english) So that right there eliminated any kit that required welding. And as for taking the kit to someone to install it? I'd rather do my own dental work than have someone touch my jeep. So even though I have had mixed results dealing with Rusty, Rusty's Bolt on Long arm kit it was. Your thoughts and experiances please?
Scott
2006 WK Overland
2014 WK2 Limited
Scottso699 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2008, 10:56 AM   #2
nierace
nierace's Avatar
2003 WJ
Is it too late to cancel?
If you make a road trip you can have Clayton install his and never look back ever again. His shop is in Waterbury, CT.
I think maybe one person has Rustys kit on here, they seemed happy with it after their install...haven't heard from them since so thats not a bad sign.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
sira4x4.net North East Offroad Club
www.carolinadriveline.com
www.ironrockoffroad.com
kolak@aol.com
nierace is offline   Reply With Quote Quick reply to this message
Unread 02-05-2008, 11:10 AM   #3
nierace
nierace's Avatar
2003 WJ
http://www.jeepforum.com/forum/showt...stys+long+arms
Nickerdoodle
35" BFGoodrich KM2
kolak@aol.com
Unread 02-05-2008, 11:14 AM   #4
PR1AWRet
2002 KJ Liberty
Being one that has the 5.5 kit, my $.02.
The kit come with everything you need. Dropped pitman arm, dropped track bar fron/rear, extended braided steel brake lines, etc. When I got it lifted with the stock D35 I had no vib issues with the stock drive shafts. So far I haven't had any problems. Its still tight and dosent squeak or rattle. Here is a post for my installation.
http://www.jeepforum.com/forum/showt...ght=locked98gc
http://www.jeepforum.com/forum/f13/rustys-rustys-rusty-5-5-long-arms-la-441767/
PR1AWRet is offline   Reply With Quote Quick reply to this message
Unread 02-05-2008, 11:15 AM   #5
Katesdad
There are a few guys around here that have Rustys kit. From what I read the liked it. The instructions were not the clearest from what I remember. But I dont have long arms so hopefully someone with Rustys will speak up
EDIT Thats the guy I was thinking of!! LOL thats kind of weird
Katesdad is offline   Reply With Quote Quick reply to this message
Unread 02-05-2008, 01:44 PM   #6
Scottso699
2006 WK
Locked98GC - great post - just what I was looking for (strange - it was a year ago yesterday you posted it) My kit should be here tomorrow. I will be combining Rusty's 5.5 inch front coils with 3.5" Rubicon Express front coils for the rear with Rubicon Front and rear track bars and Mono tube shocks. So we will see how it all works its self out. Thanks again for the info - by the way - I just talked to Rusty and he said he was not aware of any problems with the width of the transmission crossmember. So hopefully I will not have that problem!
Scott
2006 WK Overland
2014 WK2 Limited
Unread 02-05-2008, 08:08 PM   #7
sandman
seems like a good kit to me. people just dont like Rustys because they have bad customer service. this kit is affordable too, im waiting on IRO though.
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote Quick reply to this message
Unread 02-05-2008, 08:24 PM   #8
rustycherokee18
Ive been running mine for quite some time and have had no problems with it even with a 2in spacer. Like stated before i had to modify the cross memeber since i have a 98, also like stated before it does not come with the clearest directions in the world. My biggest problem was drillin the 1in wholes by the tc. i ended up havin to borrow a friends angle drill to do it but other than that its a simple install. I have rustys T-case skid and hevint figured out how to mount it with the cross memeber. I had DW pre lift and it went away once the new lift was on. The arms and brakcet are really beefy and have used and abused them many times. I slammed the jeep down on some rocks and the control arms took all the force and only had a lil nick in the paint. Aslo i heard the shocks that they come with arent the best but i had a set from the first lift i had on and they are 33in long and can max them out easily so there is plenty of flex. If you have any other questions just shoot me a pm im on regularly
1998 Zj, 4.0, 242(231/300 doubler in the process), HP60, shaved 14B, 5.38s, locked F&R, full hydro, Rusty's LA with 7in springs and ACOS, bilstein 5125 shocks, jks bar pin eliminators, jks upper shock conversions, no rear sway bar, 44in gumbos, jks discos, walmart ligh bar, cobra cd, kor radiator support, rhino lined interior, homemade winch mount, 9k winch
rustycherokee18 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2008, 09:33 PM   #9
Casper4x4
IRO is comin out with a LA kit for the ZJ hopefully sometime this year.
Alonzo "Casper" Gonzalez
1993 Jeep Grand Cherokee Laredo
4.0L Engine w/ 231 TC
IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount
Bilstein 5150 shocks
JKS Quick Disconnects
JCR 1 Ton steering
Addco Front Sway bar
Flowmaster muffler
K&N air filter
2 Pro Comp 2 KC lights on KOR light bar
Coleman roof rack
Coming Soon! Gears and locker!
Casper4x4 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2008, 08:04 AM   #10
Scottso699
2006 WK
Rustycherokee18 - thanks for the posts - I too have my own shocks and all else - just using his arms and front springs so I'll have to see how it works out.
Casper 4x4 - Just wondering... who or what is IRO?
Scott
2006 WK Overland
2014 WK2 Limited
Unread 02-06-2008, 08:09 AM   #11
nierace
nierace's Avatar
2003 WJ
Nickerdoodle
35" BFGoodrich KM2
kolak@aol.com
Unread 02-06-2008, 08:17 AM   #12
PR1AWRet
2002 KJ Liberty
Have to throw a coule of flex pics with 35's. Thats not even maxed yet, still have about 4" more in the front and 6" out back.
Unread 04-03-2008, 01:24 PM   #13
BLU88
How do the unibody framerails hold up to having a bolt-on system through them? Do they use crush sleeves on the rear control arm brackets? I was wondering if the "egg-shape" after a while? Everybody says you have to weld any kind of frame stiffener or control arm brackets. How do bolts hold up?
Lurking and asking lots and lots of questions..........
__________
/__l_l_,\____\,____
l_---l_l__l----( )jeep( )
._(o)_)__(o)_)--o-)_)
BLU88 is offline   Reply With Quote Quick reply to this message
Unread 04-03-2008, 01:28 PM   #14
zippome
not to hijack this thread, but i was the one who just emailed you about those tires you posted on craigslist.
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline   Reply With Quote Quick reply to this message
Unread 04-03-2008, 01:29 PM   #15
Scottso699
2006 WK
Rusty's uses a long thick tube spacer to go through the frame rail so that when you tighten the bolts on the brackets it doesn't crush the frame. These seem to work pretty well. The most challenging part of the install was to get the holes to line up right on both sides. We used a hole saw not a drill bit and it work a lot better and cheeper.
Scott
2006 WK Overland
2014 WK2 Limited
