Rusty bolt, broken extractor fun - Page 2 - JeepForum.com
post #16 of 24 Old 09-19-2013, 07:53 PM
zarnold
Originally Posted by 95GCL View Post
Not sure exactly how id be able to grind the bolts -- Theyre in the frame/ part of the hitch/skid plate tank. The bolt is down in the hole of where it screws into.
Your almost done, just take the bumper off, and the brackets with the nuts will slide out.
zarnold is offline
post #17 of 24 Old 09-19-2013, 08:28 PM Thread Starter
95GCL
These bolts are deep into the channel
95GCL is offline
post #18 of 24 Old 09-19-2013, 08:44 PM
newfieZJ
Ok , I know the ones you are at now . I should have compared your pics to the jeep before .
I'd take a punch , and a hammer , knock them outta there .
newfieZJ is offline
post #19 of 24 Old 09-19-2013, 09:15 PM
zarnold
Yep, I was thinking the first two. Are you working on the third bolt from the back of the jeep? I had no problem with that one. I'll take a look tomorrow evening, and see what's up.
zarnold is offline
post #20 of 24 Old 09-19-2013, 09:18 PM
newfieZJ
That's the last one in . It's just tacked on the inside . Couple good contacts and it should pop right off .
I wrap a nut tight with tie-wire and feed it back in those places . New hardware always tightens up nice and easy doing it this way .
newfieZJ is offline
post #21 of 24 Old 09-20-2013, 06:50 AM
zarnold
^ this
zarnold is offline
post #22 of 24 Old 09-20-2013, 09:50 AM
Cherokee95kid
I cut them and drilled them out took about 10 for all 4 bolts when I did it no problems.
Cherokee95kid is offline
post #23 of 24 Old 09-20-2013, 12:51 PM Thread Starter
95GCL
I mean they've been hit a good number of times already but I'll try more now that I'm out
Edit; yeah since the extractor is in there it's not moving or making much of a progress in busting it out. This thing is hella seized. My father wants to take a torch to it and heat it red hot then let it cool and repeat I believe
95GCL is offline
post #24 of 24 Old 09-20-2013, 03:03 PM
gearheadnick
If you heat it up with a torch, hit it with a punch while it's red hot. It'll be easier to shear it off. Just make sure you have some good heat resistant gloves on.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
