Rust Rust Rust, Hoping this isn't too bad.. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rust Rust Rust, Hoping this isn't too bad..
Jeep Wrangler Complete Gear Upgrade Kits with Installs andUSA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Jeep Long Arm Upgrade Kits on SALE for as low as $649.95 S
Unread 04-08-2013, 12:51 PM   #16
ZJMatt
Welcome to New Hampshire. Mine looks the same. The rest of the rockers are very solid though. That pillar is structural, but if that's the extent of your rust it's not horrible... yet. This year I plan on cutting out my rockers, reinforcing all the pillars and putting in boxed steel rockers.
Actually on a second look, pull the long kick panel off and inspect behind that too. It may not have gotten to the structure yet.
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline   Reply With Quote Quick reply to this message
Unread 04-08-2013, 01:14 PM   #17
DickDickle
New England is rough I ended up cutting out my rockers and replaced them with 3 inch square tubing the length of the rockets on covering it with angled steel plate
DickDickle is offline   Reply With Quote Quick reply to this message
Unread 04-08-2013, 04:30 PM   #18
CanaanTSA5
CanaanTSA5's Avatar
Its started under it. I'm going to take them all off when I get that convertor stuff in.
1998 ZJ 4.0 Stock 225/75R15 General Grabber AT2
184,000mi
CanaanTSA5 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2013, 04:39 PM   #19
ratmonkey
R.I.P.
ratmonkey's Avatar
only sure way to fix that is to cut all the rust out, weld in new metal, THEN apply the rust preventative paints, like chassis saver, over the good stuff.
that's pretty bad on a structural member right there.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 04-08-2013, 04:45 PM   #20
CanaanTSA5
CanaanTSA5's Avatar
Eventually I will. But I just don't have the means to do that myself, and I don't have the money to have a shop do it.
184,000mi
