Rust On My JGC. Help - JeepForum.com
post #1 of 4 Old 05-21-2009, 05:51 PM Thread Starter
miketigr1234
My 04 JGC has some small rust spots right near the headlights where they curve. It happen when using a scewdriver to take the headlights off. What can i do to take the rust off and put factory paint on? Can i like sand it down then buy the bush factory paint at autozone and bush it on or what. Thanks so much.
miketigr1234 is offline
post #2 of 4 Old 05-21-2009, 06:16 PM
cmonson
You can buy sandpaper anywhere, and buy the maching paint at the dealer. If it is just a small amount (like a rockchip) I use a rotary tool with a fine grit stone. Get down to shiny metal, then touch it up with 3-5 coats of mopar matching paint.
If you want a PERFECT match, you can wet sand and buff.
But... You shouldn't call you Jeep a Jeep without some scars.
cmonson is offline
post #3 of 4 Old 05-21-2009, 07:05 PM
gatorayde
Yep, a little bit of careful sanding and some touch up paint and you're good to go.
gatorayde is offline
post #4 of 4 Old 05-21-2009, 07:59 PM
energy0uth
make sure to clean before and after as well...you want the paint to stick well
energy0uth is offline
uh oh.. Rust! monjon WJ Grand Cherokee Forum 36 03-24-2010 08:30 PM
Rust!!! colt808 ZJ Grand Cherokee Forum 2 11-02-2009 05:23 AM
Is this rust? 01wrangler WK Grand Cherokee & XK Commander Forum 19 01-24-2009 09:15 PM
oil pan rust Granam73 ZJ Grand Cherokee Forum 13 12-10-2008 07:50 PM
Rust?????? onlyone WJ Grand Cherokee Forum 4 02-08-2004 07:28 PM
