Rust hole below pcm - JeepForum.com
post #1 of 3 Old 02-18-2013, 04:42 PM Thread Starter
Freestyle713
1994 ZJ
Rust hole below pcm
So I found a spot in my inner fender that rotted through to the inside of the engine bay. I can see the bottom of my pcm through it, so its kind of a priority to get it plugged up, and I'm looking at my options of doing so before it gets wet. I have some 10 gauge steel laying around, I can cut out a section of the wheel well and patch it with that, or should I not even bother and just use some of that great stuff spray insulation? Or both?
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #2 of 3 Old 02-18-2013, 05:10 PM
nickpequignot
I would cut it out and get all the rust out and then weld in the 10ga like you said. Then spray it and call it good.
nickpequignot is offline
post #3 of 3 Old 02-18-2013, 08:23 PM
ZeeJay1997
Be sure to protect the wiring.
ZeeJay1997 is offline
