Running a TJ swaybar with Clayton LA's? - JeepForum.com
post #1 of 11 Old 01-14-2014, 01:44 PM Thread Starter
OverlandZJ
Picking up a Clayton rear upgrade kit for the ZJ soon, from what I'v read there can be clearance issues with the OEM ZJ swaybar on uptravel.
Assuming a few guys here have swapped a TJ in, I'd like to see what links you used and how you attached to the unirail. Pics would be helpful.
Thanks..
OverlandZJ is offline
post #2 of 11 Old 01-14-2014, 05:18 PM
darkhelmet
I just installed a claytons LA kit on mine so am curious on this now as well? What is the advantages to the tj swaybar?
98 Grand Cherokee 5.2l converting to a cheap trail rig
http://video.adultswim.com/robot-chicken/our-newest-member-calvin.html
ZJ's: If you dont know what it is you cant afford it.
darkhelmet is offline
post #3 of 11 Old 01-14-2014, 07:23 PM
speedbucket
I yanked my rear sway bar a long time ago. Why would you need it?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #4 of 11 Old 01-14-2014, 07:50 PM
darkhelmet
speed.. do you have the front sway still on??
post #5 of 11 Old 01-14-2014, 07:58 PM
speedbucket
Absolutely. Front sway is an absolute must. The only way I'd ditch that is if I decide on buying some ori struts
post #6 of 11 Old 01-14-2014, 08:31 PM
MurdaJs
MurdaJs is offline
post #7 of 11 Old 01-14-2014, 08:33 PM
LordHobbit
I don't notice not having a rear sway. Maybe if I put one in then I'd notice.
Ratmonkey, may he rest in peace, had one on his 8.8 and claytons. Can't remember if it was because he liked it or only because he needed it to pass inspection.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #8 of 11 Old 01-15-2014, 08:53 AM Thread Starter
OverlandZJ
Potentially pulling a trailer ~1500lbs cross country. Excellent road manners are a requirement for me which is why i'm upgrading from SA's. I'v already got Clayton kit up front.
Originally Posted by MurdaJs View Post
Yeah, I bumped that the other day. Sudz is a local bud of mine and the one who first mentioned the TJ swaybar. I like the way he spaced out the links and used the OEM upper arm bolt location, but I think I'd prefer regular links such as Ted's. Figured I might get a better/different idea from members here.
Thanks for the tip, i'll check Rat's build.
post #9 of 11 Old 01-15-2014, 09:53 AM
Technohead
Agreed. The rear sway bars were engineered to fine tune the steering characteristics of the stock suspension. Why on Earth would anybody expect it to do something useful with a completely different suspension design?
-Eric
Technohead is offline
post #10 of 11 Old 01-15-2014, 11:06 AM
speedbucket
I follow and understand your point. The tj front is 1 1/8" diameter like the zj front iirc. The factoru zj front with poly bushings is enough at the height of my zj to feel tire roll long before any uncomfortable body roll. I can take offramps and feel more stable than my wife's stock quad cab dakota. I'm thinking some of that has to do with frame plating, steering brace and stout front bumper/ tie ins.
As far as his towing a trailer I'm not sure what a rear sway bar would accomplish unless his front bushings were lacking.
post #11 of 11 Old 01-15-2014, 02:18 PM Thread Starter
OverlandZJ
Keep in mind I don't yet have the LA's out back.. but in my research i'v seen plenty of guys who are running one and found it beneficial. Keep in mind this isn't an all rock's build.
The guys who I have seen add a TJ swaybar are all guys with plenty of experience and knowledge, i'll trust their judgement that they found a need. I guess I'd just prefer to run one..
Borrowed pic of a bud's setup...
