Quantcast running an ipod cable from back of cd player down to glovebox. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > running an ipod cable from back of cd player down to glovebox.
Old 03-01-2007, 11:52 PM   #1
djdoug99
Can someone please tell me the easiest way to run an ipod cable from the back of my alpine cd player to the glovebox where it would obviously connect to my ipod.
djdoug99 is offline   Reply With Quote
Old 03-02-2007, 12:11 AM   #2
slick2570
what kind..
You gotta ZJ or WJ???
-Eric
2003 TJ Rubicon - stock for now
1999 WJ - Gone
slick2570 is offline   Reply With Quote
Old 03-02-2007, 12:13 AM   #3
QuadraTokn
1930 WJ
what jeep do you have and what year is it? you might want to put that in your sig at least.
i have mine popping out underneath the ashtray / outlet. i believe its the most logical/closest/easiest location
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 03-02-2007, 12:16 AM   #4
BigItalianBeast
im guessin you have a 99 judging by you SN...what i did as a temporary solution is ran it along the front side of the air conditioning vent like to the farthest right (if that makes sense) and into the glove...its concealed and you cant see it in the air conditioning vent unless you look for it
Josh
1999 WJ 4x4 Laredo
I-6/4.0, 255/70/18 JKs, 2" BB
OME Steering Stabilizer, FMS40,Pioneer 4900 DVD, 15% Tint, Subs
BigItalianBeast is offline   Reply With Quote
Old 03-02-2007, 12:20 AM   #5
djdoug99
sorry I have a 96 zj
Old 03-02-2007, 12:35 AM   #6
QuadraTokn
1930 WJ
yea then id run it straight down, u know, where the shifter is, but if u want it in the glove box then idk
Tread Lightly
Pictures
Old 03-02-2007, 07:33 AM   #7
98ZJ SFD
I have mine come out by the 4WD lever.
R.I.P. 98 ZJ Laredo SE 4.0, 42RE, 242, 2" Skyjacker BB, JKS Quicker Discos, Rancho steering stabilizer, Goodyear Wrangler MT/Rs, K&N FIPK, Kolak cat & back exhaust, 1200W 15" Cadence Beast subwoofer, Westin Safari bar, KC lights, Whelen siren, Whelen strobe lights, Whelen Slimlighter.
98ZJ SFD is offline   Reply With Quote
Old 03-03-2007, 01:39 AM   #8
slick2570
installing..
I would put it in the glove box because when it is hooked up to the stereo its not like you can control the songs through it or anything, so i'd just run it up into the dash.. Is there not a little bit of an opening to have it come in from the top of the left side of the glove box? Sometimes you have to drill a hole big enough to slide it in through. (if you do have to drill, make sure you slide it in backwards, starting from the glove box and going to the radio. Most of the times it is just a small round plug instead of the very wide ipod plug.) Hope that helps out!
-Eric
1999 WJ - Gone
Old 03-03-2007, 02:47 AM   #9
Arkansas_WJ
i ran mine to the center console so i can still change play lists and crap at stop light.
Much more convenient
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline   Reply With Quote
Old 03-03-2007, 02:58 AM   #10
slick2570
cant when plugged in..
If you have an aftermarket stereo and have it plugged in via iPod interface cable, it usually makes the screen say "ALPINE" or "PIONEER" whatever the company, and you can't navigate through the menu's and such.. I could be wrong.. But if that is the case, then it would be better to have it in the glovebox since you can't use it while plugged in anyways. Plus, its better for security because if you leave it in the car while you run in somewhere, it is out of the way and no one knows that you have an ipod in there.. just a tip! Later
-Eric
1999 WJ - Gone
Glock Forum
