Running interior power ACC line? - JeepForum.com
post #1 of 10 Old 10-16-2013, 03:38 PM Thread Starter
Gearhead31
I've been thinking of tapping a full power line to the rear of the vehicle for various accessory uses. I use a lot of random 12v accessories all the time(dash fan, mini air compressor, emergency lights, etc) and would like to just run a power line straight off the batt to inside the rear cargo area. I will probably have it end in a distribution block with a 12 v outlet right beside it or something of the like. Any thoughts aside from 100% fused protection at the batt I should do to avoid it backfiring in my face?
All the threads that have anything like this are filled with 404 error links or just not relevant.. I guess the questions
Do any of you have a recommendation for a good 4-6 port distribution block(don't need bigger than 8 gauge off the block) that's on the cheap?(please no crutchfield parts or anything, they are ridiculously expensive for cheap crap)
For that use, incase of emergencies, is it even worth relays, or should I just wire in a cut off switch at some place? Relays are my weak spot with electrical *shrugs*
I'm trying to think as plug-and-play as I can be with this for versatility as I'll probably be getting a full set of rv type appliances for camping trips or cross country trips.
One thing I was planning for this was using that as a tapping point to run a 12v higher amp power line to a trailer so I can hook up stuff like an rv fridge/freezer. That's still up in the air as to how well it would work.. I was thinking run it alongside the 4 prong connector and as a second "extension cord" of sorts. There's also the line of thought that I might add a battery or two onto the trailer and use that as a sort of "slow charge" connection(though that would probably be a larger independant line, idk..). Just throwing out where my train of thoughts has been for this so you all can add your ideas, advice, whatever
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #2 of 10 Old 10-25-2013, 03:09 PM
jimmyznutz
1994 ZJ
An excellent idea on the cargo area power source. Sounds like it would be easily doable. Just run an 8 or 10 gauge power wire to the rear. Just like you would for an amp. Find the place you want the outlet and integrate it in the trim, I would put a cutoff switch also just for safety. Use parts like this.
A couple of these.
a cutoff switch.
I would also integrate one of these somehow since doing the work anyway.
This would be a nice option if you could find this setup.
jimmyznutz is offline
post #3 of 10 Old 10-25-2013, 03:30 PM Thread Starter
Gearhead31
hmm.. That has a lot of possibility. Thanks! That's not exactly what I'm planning but that's a really good idea, and I can think of a lot to go from there.
Any other takers? I'm sure this could be innovation for others, since there doesn't seem to be much coverage on this for ZJs.
post #4 of 10 Old 10-25-2013, 07:57 PM
Mickey_D
Depending on how much wattage you're going to pull from it, I would tap into the upper left tab on the trailer connector. It's ignition switched, though.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #5 of 10 Old 10-25-2013, 08:23 PM
kachink
I'd like to set up so the battery in my trailer charges while I'm driving. There are a few writeups on installing a 2nd battery & how to wire it so it's isolated.
I've used Del City for junctions blocks, wire, connectors, etc.
kachink is offline
post #6 of 10 Old 10-25-2013, 08:31 PM Thread Starter
Gearhead31
There is only a 4 pin(blade) style trailer light kit that I installed a couple weeks ago. That plus the avg draw would be between 5a and 15a, highest expected being around 80ish amps draw.
post #7 of 10 Old 10-25-2013, 08:31 PM
Mickey_D
Using the connection I posted will do that. In fact, that's what it's for. You will of course need to wire in a 7 pin connector on the trailer to make use of it. The "battery" connection at the upper left of the Jeep's trailer connector is direct power that is switched off and on with the ignition. As soon as you start the Jeep with the trailer plugged in, it will start charging the trailer's battery. As soon as you shut the Jeep off, the trailer is isolated and on its own.
________________
#4
Mickey_D is offline
post #8 of 10 Old 10-25-2013, 08:32 PM Thread Starter
Gearhead31
This computer is lagging i guess, I can't seem to keep up with posts tonight.
I'll check out del city, they seem promising so far.
Along the lines of multi-battery, It would be batteries buffering accessories(appliances, lights, etc) and the alternator providing the brunt power and recharge. I'm thinking camping and cross country with the trailer and some stuff thrown in cargo racks for offroading trips, but still packed into a DD vehicle. I see it all the time in the larger trucks and want a smaller, more versatile version that doesn't kill me with weight and power drain
It looks like the only place around here that sells anything bigger than 4 gauge wire in jumper cables is grainger.. Any thoughts?
post #9 of 10 Old 10-25-2013, 08:41 PM
96zedjay
Crumpton Welding Supply
St. Petersburg branch:
3007 47th Ave. N. - St. Petersburg, FL 33714
727-525-2177 - 800-201-2177
96zedjay is offline
post #10 of 10 Old 10-28-2013, 01:14 PM Thread Starter
Gearhead31
Thanks 96zedjay! That didn't come up on any of the searches. Go figure, search for something several hundred miles away and you can find 20 of everything. search for something 5 miles away, it doesn't exist.... Gotta love Google sometimes >_<
