Running 3" BB on a 96 GC - JeepForum.com
post #1 of 18 Old 09-23-2009, 08:01 AM Thread Starter
Swedishguy
Hello!
New at the forum. Just bought a 96 ZJ and one night I put together a 3" BB lift made out of teflon pucks. But now im stumbleling over more and more negative response around the 3" BB's? Am I gonna crash and burn? Why is it such a
Has had it on now for 2 weeks and it seems to work like a charm!
Thanx
Swedishguy is offline
post #2 of 18 Old 09-23-2009, 08:03 AM
spife7980
its frowned upin becasue at that height it lowers the spring so mauc that it is very easy for it to come unseated due to there not being much or any spring retainer post left to hold it in. and if you loose a spring it isnt good.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #3 of 18 Old 09-23-2009, 08:06 AM
NEp8ntballer
because your suspension geometry is no longer anywhere near where it should be. plus you don't get the much of a gain with the pucks as opposed to a 3" lift spring. you can clear bigger tires but you don't gain the articulation from a 3" lift.
NEp8ntballer is offline
post #4 of 18 Old 09-23-2009, 08:21 AM Thread Starter
Swedishguy
Ok! thanx for the quick reply! In the front theres the long bump-stoppers to hold the spring in place. So the problem is mostly the rear springs that now risk coming unseated?
post #5 of 18 Old 09-23-2009, 08:49 AM
spife7980
yes, you are correct, but if you flex the front a decent amount there is still the possibility. its just frowned upin as an unsafe practice. kind of a dont risk it if you dont have to.
did you get any other components at 3" or just the pucks?
-James
post #6 of 18 Old 09-23-2009, 09:06 AM Thread Starter
Swedishguy
Just the Pucks, gonna get the shocks to. Havent decided on wich ones yet. I have seen that the alignment in the axels are a bit off since i havent done anything with the panhard. Thinking of drilling a new hole in the lower bracket in the front. Havent thought much abot the rear yet. Btw, its 2,5" pucks on the rear springs, not 3".
post #7 of 18 Old 09-23-2009, 09:17 AM
WhiteOut
WhiteOut's Avatar
If its 2.5" then its fine, I ran 2.5" for almost a year with no issues.
WhiteOut is offline
post #8 of 18 Old 09-23-2009, 09:35 AM Thread Starter
Swedishguy
2,5" rear, 3" front
post #9 of 18 Old 09-23-2009, 04:12 PM
StellaTheZJ
I've been running a 3" BB for 0ver 10 years, some 300,000kms, on two trucks. There are no problems with the front coming loose ever, even at full droop, even with the shocks and swaybar off, because the OEM lower control arms prevent the diff from dropping far enough. In addition, the front bumpstop post is over 5" long, plus the steel bumpstop socket os bolted on to the end of that. When you put BBs in the front, it is always under at least a bit of compression, even under full droop, because there is less "room" for the spring than before! In other words, a BB actually makes the springs harder to remove, so harder to have "fall out." Where did this myth start??
In the rear, there may be some concern. The spring is located by a much shorter post. The solution for those who want a 3" BB is to install a piece of exhaust tubing over the post and then install the suspension. I have not done this, and I wouldn't bother, because you can get the same 3" of lift from a Front to Rear swap using I6 ZJ springs. No problems with the spring ever moving, and used springs are cheaper than BBs in my areas. Actually though, even with the swaybar and shocks off, the springs are hard to get in with a 2" BB. I can't imagine they'd be able to move (especially with the swaybar and shocks on!), because with the OEM LCAs, the rear springs are ALWAYS under pressure, even at full droop.
In either case, you will not have any trouble with articulation. Check out my Public Profile pic and you'll see my 31s rubbing the top of the spring post, even with the 3" BB. I've extended the front bumpstops 1" (a simple aluminum puck) and the rear 1.5" (square steel tubing, actually from a RE kit).
You will have no issues with front end geometry, as you can adjust the caster so easily on the ZJ.
You will definitely have vibration issues with the stock rear suspension, but they can be "reduced" with a transfer case drop. Or hopefully removed with adjustable lower control arms.
There is NO CHANGE in ride quality with a BB (another weird myth???) because you're using the same springs!!
Enjoy it!
StellaTheZJ is offline
post #10 of 18 Old 09-24-2009, 12:43 PM Thread Starter
Swedishguy
Good stuff! Thanx for all the info! Gonna consider my options, leaning towards keeping the pucks in the front and throw in some used frontsprings on the rear axle.
Great forum btw!
post #11 of 18 Old 09-24-2009, 04:16 PM
sandman
Great forum btw!
if your really on a budget thats the way i would do it. your gonna need longer shocks too.
1993 Jeep ZJ. 4.0
sandman is offline
post #12 of 18 Old 09-24-2009, 04:49 PM
BigJake3030
1992 XJ Cherokee
Does anyone know how much lift you will get by putting the stock 5.2 springs in the rear. I was thinking of doing this and buying lift springs for the front to keep it level. I was also wondering if both the front and rear track bars need to be replaced or just the front?
BigJake3030 is offline
post #13 of 18 Old 09-24-2009, 05:05 PM
spife7980
that is commonly called the front to rear swap. ironrockoffroad.com has a kit made for it. they should give 3.5" in the rear. if you move em back and get new front 3.5" springs you will want new shocks made for a 3.5" lift, a front trackbar and longer swaybar endlinks to go with it at a minimum. some people ty and get by without a new rear trackbar but in my personal opinion i would highly recommend a new rear trackbar. im very pleased i got it and some people who dont end up with weird rubbing issues caused by not getting it and end up with it.
if you dont plan on wheeling it you can get by with relocation brackets that will drop the mount down butim unsure of those. ive heard some horor stories that arise with em and i personally am not comfortable with em.
-James
post #14 of 18 Old 09-24-2009, 05:20 PM
BigJake3030
1992 XJ Cherokee
Thanks for the advice, Im off road all the time but mostly family trails and lighter stuff. I feel the same way about those relocation brackets, heard to many bad stories. So being stock now and fitting 31 fine w/ 3.5 inches of lift I should be able to clear 32" tires easy right. Thanks-
post #15 of 18 Old 09-24-2009, 09:18 PM
spife7980
i know right of the bat moonyjohn is running 32s and im on 265s so you should be good. might have to trim a little bumper depending on your specific vehicle but it shouldnt be anything major at all.
-James
"Popping" while engine running Haasie ZJ Grand Cherokee Forum 2 03-01-2010 03:19 AM
running lights stay on in "off" position sappi285 ZJ Grand Cherokee Forum 0 12-27-2009 02:34 PM
Anyone Running 31" Tires On IRO 4.5" Kit? RrCoX22 ZJ Grand Cherokee Forum 16 03-13-2009 02:27 PM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 11:23 AM
running 33 with a 4.5" kit on a 93 ZJ jeep0104 ZJ Grand Cherokee Forum 6 09-12-2006 07:50 PM
